Hi, have two laptops one is a acer aspire 7000 which was using vista but i installed xp on it. now i have all the drivers on it but in the hardware manager i have a modem device on High def audio bus coming up. now i have downloaded and installed the drivers from their site does anyone know where i can get a driver that would work for this? also the other laptop is a zoostorm 8615p i d1 and i cant find any drivers for that? any help would be great.
Results 1 to 10 of 10
The Acer is easy:
http://support.acer-euro.com/drivers/notebook/as_7000.html
The Zoostorm is a completely different matter. Their website says about support and downloads: "coming soon".
None of the retailers offer downloads. Unless you can locate the original driver disc, you're pretty much screwed.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Much better chance. If you can locate the video card specs (maybe in device manager???), sound card, etc., you stand a chance. My reason for buying main brand machines - I went for years doing driver searches for mobo and card combinations when I built my own.
Make sure you have downloaded the power management software for XP from the Acer site. You may suffer overheating and damage if the Acer power management is absent.
np, found them all last night and working great all for ur help 8)
I got the same problem:Originally Posted by Mr anderson
their technical support emailed me drivers can all be downloaded 'from internet';
but I don't even know what the hardwares are.
can i ask how did you sort out your problem please
thank you
driver help
By romanstopme in forum ComputerReplies: 1Last Post: 19th Nov 2009, 00:30 -
Driver Copy
By CSULB71 in forum ComputerReplies: 0Last Post: 11th Jul 2009, 19:57 -
HP Ethernet Driver
By Sportster Freak in forum ComputerReplies: 14Last Post: 19th Mar 2009, 19:02 -
Are you a distracted driver?
By yoda313 in forum PollsReplies: 41Last Post: 23rd Apr 2008, 23:27 -
What kind of driver are you?
By yoda313 in forum PollsReplies: 29Last Post: 18th Sep 2007, 11:26
