Hello folks,
I own a laptop, an IBM thinkpad with an ATI Mobilty FireGL V3200 graphic-card. I have lot of avi files whom I want to watch on my fatscreen without burning onto a DVD. The computer is equipped with S-VHS and VGA of course, while the TV is equipped with S-VHS, RGB via Scart. What is the easiest way to install the computer to the TV so I can transfer the image?
Mark
The laptop has to play out to the tv somehow. My HP laptops have s-video output (one uses nVidia something, one uses ATI Mobility x900), and both look great. There's nothing to "install". I do dualview, so I can still look at the laptop screen, and the tv is a second monitor.
Thanks mate,Originally Posted by lordsmurf
As a newbie, the only thing I have to do is to plug in the S-VHS cable into the laptop and the TV, and then put the TV on the S-VHS channel?
Mark -
"S-VHS" is a tape format (Super VHS).
"s-video" is a wire standard (separated video).
Plug the s-video into the computer output, and into the tv input.
Tell your computer to display out onto tv if it doesn't do it automatically.
Read the manual if you don't know how. Neither do I, mine is probably different than yours.Want my help? Ask here! (not via PM!)
What's a "fatscreen"? An extra-wide TV?Originally Posted by Belfour
A fatscreen is a 28" widescreen-TV from Panasonic, 1996. It only has s-video and RGB.Originally Posted by AlanHK
Mark
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
Help laptop to tv
By celecon in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 15:53 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56
