How do you reorder the movies? Right now they are in the order that I created them in, which (I think) means pressing >> or << on the dvd remote while playing will take you to the next movie in the order that I created them, not the order which I want them to be played in. In the connections view I can see the movie number in black...that's what I'm trying to change. Thanks.
I am afraid that only easy way to do it is ti reathor your project and place movies in order you want them to play. Changing movie number, like Movie 1 to Movie 3 will not change the order, they go be PGC numbers (small red number, top left corner).
Only other way is to modify commands. -
You can also make your play order a function of the how the buttons are linked - i.e. move the movies around on the "connections veiw" and redirect your buttons to work accordingly (as tinker mentioned), but that can get confusing. I usually just put them in in the order I want to work with them.
Sorry, I forgot about Playlist. That is way to play in sequence you want.
I am not sure if << or >> remount buttons will work, but you can make menu button connected to Playlist and individual buttons to play each movie. -
If you currently have your movies linked one after the other
e.g. 1 -> 2 -> 3 -> 4
in the cionnections window, all you have to do is draw new links to change the order.
e.g. 1 -> 3 -> 2 -> 4
The number doesn't matter unless you use the number keys to skip. The movies play in the order of the links in the connections window.
You can use a playlist to do this as well, but playlists are usually used if you have the same material being played in several different orders. In your case it is simpler to just redraw the arrows.Read my blog here.
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 01:13 -
Can i actualy preview the subs in the movie in DVD Lab ?
By mordor in forum SubtitleReplies: 0Last Post: 22nd Mar 2008, 09:02 -
DVD Lab Pro - Question about movie merge
By shashidar in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 15:41 -
DVD Lab Pro - Movie clips in menu
By flipzoso in forum Authoring (DVD)Replies: 1Last Post: 26th Oct 2007, 02:38
