hi,
does anyone know of any freeware that will allow me to view the timeline in "frameshot" manner of an mpeg2 (vob) file?
i'm trying to quickly identify places where there are commercials and subsequently cut/remove them...
VirtualDub_MPEG, mpg2cut2, mpeg Streamclip, etc can do it but I need to go frame by frame to locate where the commercials are... if there's a timeline of the "frameshot", i can easily scroll left / right to locate them...
thanks !
Results 1 to 12 of 12
Cuttermaran. But you have to demux to elementary streams first. It has a quick jump feature that allows you to easily spot where the commercials are.
Buy My Books -
I use DVD Shrink in re-author mode to cut commercials. Well, you actually have to pick what you want to save...
Also for me Tmpgenc Mpeg Editor is the program of choice for precise MPEG editing.
Too bad the build in editor of TDA does not make clean MPEG2 cuts.Originally Posted by mats.hogberg
(Not sure if this issue is corrected in the new TDA V3?)
Audio/video break in DVD Author? -
In what way aren't they clean?Originally Posted by The_Doman
/Mats -
I can't say really.Originally Posted by mats.hogberg
I, and other people, noticed slight pauses with some standalone DVD players on the cut/edit points when editing with TDA 1.6/2.x.
When editing the file with for example Tmpgenc Mpeg Editor before authoring with TDA those pauses are not there. -
OK - I've not noticed any such problems. Probably own players not affected by this.
/Mats
Removing commercials from a DVD video
By solarblast in forum Capturing and VCRReplies: 9Last Post: 10th Sep 2011, 04:35 -
Help - Need to remove commercials & other bits & pieces from TV show
By jcikal in forum EditingReplies: 1Last Post: 7th May 2010, 16:36 -
advice converting to XviD + removing commercials
By Colbey in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2010, 20:29 -
Removing commercials from TIVOed shows
By Fantome in forum Video ConversionReplies: 3Last Post: 6th May 2009, 15:09 -
Recommend a freeware for removing recorded commercials
By pannayar in forum EditingReplies: 23Last Post: 2nd Sep 2008, 19:33
