I routinely encode avi files with subtitles (AVI to DVD mpeg2enc). The result is a Video T_S folder which I can then burn to DVD using Toast, and play on a stand alone DVD player.
However, this weekend, all of a sudden, several different files did not result in T_S folders at all, just a list of five files:
Auction.House.E03.avi.ff.ac3
Auction.House.E03.avi.ff.m2v
Auction.House.E03.avi.ff.mpg
Auction.House.E03.avi.ff.mpg.s.mpg
Auction.House.E03.avi.ff.mpg.xml
Other files from the same source burned fine and resulted in T_S folders. I tried encoding repeatedly to no avail.
Any ideas? Thank you!
	• Check to see if Author as DVD is still set (Options tab), before encoding.
 • You could try to continue where it stopped by using the Author Tool, in the Tools tab, author subtab.
 • Please post the Process Information ('log') from the ffmpegX Progress window (blue "i"), in order to find error messages that might help diagnose this.
	Yes, Author as DVD (VIDEO_TS) is selected. I did not know that the file was not completed as the ffmegX Progress window listed it as finished.
 Here is the log (thank you for your explicit instructions!).
 INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
 INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
 INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
 Sat Jan 19 03:21:51 HST 2008
 INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
 INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030)
 INFO: [yuvscaler] input: interlace: none/progressive
 INFO: [yuvscaler] input: sample aspect ratio: 1:1
 INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
 INFO: [yuvscaler] scale to 720x480, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
 INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
 INFO: [yuvscaler] without line switching
 INFO: [yuvscaler] without time forwarding
 INFO: [yuvscaler] Without luminance correction
 INFO: [yuvscaler] Without chrominance correction
 INFO: [yuvscaler] frame rate: 29.970 fps
 INFO: [yuvscaler] Scaling ratio for width is 1 to 1
 INFO: [yuvscaler] and is 1 to 1 for height
 INFO: [yuvscaler] Specific downscaling routing number 4
 INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
 INFO: [yuvscaler] output: frame rate: 30000/1001 fps (~29.970030)
 INFO: [yuvscaler] output: interlace: none/progressive
 INFO: [yuvscaler] output: sample aspect ratio: 1:1
 INFO: [mpeg2enc] Selecting DVD output profile
 INFO: [mpeg2enc] Assuming norm NTSC
 INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/kk/Movies/Azureus/Auction.House.E03.avi.ff.m2v
 INFO: [mpeg2enc] Horizontal size: 720 pel
 INFO: [mpeg2enc] Vertical size: 480 pel
 INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
 INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
 INFO: [mpeg2enc] Bitrate: 2439 KBit/s
 INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
 INFO: [mpeg2enc] Field order for input: none/progressive
 INFO: [mpeg2enc] New Sequence every 9999 Mbytes
 INFO: [mpeg2enc] Assuming non-video stream of 0 Kbps
 INFO: [mpeg2enc] Search radius: 16
 INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
 INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
 INFO: [mpeg2enc] Progressive format frames = 1
 INFO: [mpeg2enc] Using default unmodified quantization matrices
 INFO: [mpeg2enc] Buffering 39 frames
 INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
 INFO: [mpeg2enc] SETTING AltiVec for MOTION!
 INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
 INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
 INFO: [yuvscaler] End of stream!
 INFO: [yuvscaler] Normal exit: end of stream with frame number 113072!
 INFO: [mpeg2enc] Guesstimated final muxed size = 1123086470
 Computing levels...
 Auction.House.E03 --% done, ETA --:--:-- (batch 0% done, ETA 99:14:08)
 Auction.House.E03 1% done, ETA 00:01:39 (batch 1% done, ETA 00:01:39)
 Auction.House.E03 2% done, ETA 00:01:38 (batch 2% done, ETA 00:01:38)
 Auction.House.E03 3% done, ETA 00:01:05 (batch 3% done, ETA 00:01:05)
 Auction.House.E03 4% done, ETA 00:01:12 (batch 4% done, ETA 00:01:12)
 Auction.House.E03 5% done, ETA 00:00:57 (batch 5% done, ETA 00:00:57)
 Auction.House.E03 6% done, ETA 00:01:03 (batch 6% done, ETA 00:01:03)
 Auction.House.E03 7% done, ETA 00:00:53 (batch 7% done, ETA 00:00:53)
 Auction.House.E03 8% done, ETA 00:00:57 (batch 8% done, ETA 00:00:57)
 Auction.House.E03 9% done, ETA 00:00:51 (batch 9% done, ETA 00:00:51)
 Auction.House.E03 10% done, ETA 00:00:54 (batch 10% done, ETA 00:00:54)
 Auction.House.E03 11% done, ETA 00:00:49 (batch 11% done, ETA 00:00:49)
 Auction.House.E03 12% done, ETA 00:00:51 (batch 12% done, ETA 00:00:51)
 Auction.House.E03 13% done, ETA 00:00:47 (batch 13% done, ETA 00:00:47)
 Auction.House.E03 14% done, ETA 00:00:49 (batch 14% done, ETA 00:00:49)
 Auction.House.E03 15% done, ETA 00:00:45 (batch 15% done, ETA 00:00:45)
 Auction.House.E03 16% done, ETA 00:00:47 (batch 16% done, ETA 00:00:47)
 Auction.House.E03 17% done, ETA 00:00:44 (batch 17% done, ETA 00:00:44)
 Auction.House.E03 18% done, ETA 00:00:46 (batch 18% done, ETA 00:00:46)
 Auction.House.E03 19% done, ETA 00:00:43 (batch 19% done, ETA 00:00:43)
 Auction.House.E03 20% done, ETA 00:00:40 (batch 20% done, ETA 00:00:40)
 Auction.House.E03 21% done, ETA 00:00:41 (batch 21% done, ETA 00:00:41)
 Auction.House.E03 22% done, ETA 00:00:39 (batch 22% done, ETA 00:00:39)
 Auction.House.E03 23% done, ETA 00:00:40 (batch 23% done, ETA 00:00:40)
 Auction.House.E03 24% done, ETA 00:00:41 (batch 24% done, ETA 00:00:41)
 Auction.House.E03 25% done, ETA 00:00:39 (batch 25% done, ETA 00:00:39)
 Auction.House.E03 26% done, ETA 00:00:40 (batch 26% done, ETA 00:00:40)
 Auction.House.E03 27% done, ETA 00:00:38 (batch 27% done, ETA 00:00:38)
 Auction.House.E03 28% done, ETA 00:00:36 (batch 28% done, ETA 00:00:36)
 Auction.House.E03 29% done, ETA 00:00:37 (batch 29% done, ETA 00:00:37)
 Auction.House.E03 30% done, ETA 00:00:35 (batch 30% done, ETA 00:00:35)
 Auction.House.E03 31% done, ETA 00:00:36 (batch 31% done, ETA 00:00:36)
 Auction.House.E03 32% done, ETA 00:00:34 (batch 32% done, ETA 00:00:34)
 Auction.House.E03 33% done, ETA 00:00:32 (batch 33% done, ETA 00:00:32)
 Auction.House.E03 34% done, ETA 00:00:33 (batch 34% done, ETA 00:00:33)
 Auction.House.E03 35% done, ETA 00:00:32 (batch 35% done, ETA 00:00:32)
 Auction.House.E03 36% done, ETA 00:00:30 (batch 36% done, ETA 00:00:30)
 Auction.House.E03 37% done, ETA 00:00:29 (batch 37% done, ETA 00:00:29)
 Auction.House.E03 38% done, ETA 00:00:28 (batch 38% done, ETA 00:00:28)
 Auction.House.E03 39% done, ETA 00:00:27 (batch 39% done, ETA 00:00:27)
 Auction.House.E03 40% done, ETA 00:00:25 (batch 40% done, ETA 00:00:26)
 Auction.House.E03 41% done, ETA 00:00:26 (batch 41% done, ETA 00:00:26)
 Auction.House.E03 42% done, ETA 00:00:25 (batch 42% done, ETA 00:00:25)
 Auction.House.E03 43% done, ETA 00:00:24 (batch 43% done, ETA 00:00:24)
 Auction.House.E03 44% done, ETA 00:00:23 (batch 44% done, ETA 00:00:23)
 Auction.House.E03 45% done, ETA 00:00:22 (batch 45% done, ETA 00:00:22)
 Auction.House.E03 46% done, ETA 00:00:21 (batch 46% done, ETA 00:00:21)
 Auction.House.E03 47% done, ETA 00:00:20 (batch 47% done, ETA 00:00:20)
 Auction.House.E03 48% done, ETA 00:00:19 (batch 48% done, ETA 00:00:19)
 Auction.House.E03 49% done, ETA 00:00:20 (batch 49% done, ETA 00:00:20)
 Auction.House.E03 50% done, ETA 00:00:19 (batch 50% done, ETA 00:00:19)
 Auction.House.E03 51% done, ETA 00:00:18 (batch 51% done, ETA 00:00:18)
 Auction.House.E03 52% done, ETA 00:00:18 (batch 52% done, ETA 00:00:18)
 Auction.House.E03 53% done, ETA 00:00:17 (batch 53% done, ETA 00:00:17)
 Auction.House.E03 54% done, ETA 00:00:16 (batch 54% done, ETA 00:00:16)
 Auction.House.E03 55% done, ETA 00:00:16 (batch 55% done, ETA 00:00:16)
 Auction.House.E03 56% done, ETA 00:00:15 (batch 56% done, ETA 00:00:15)
 Auction.House.E03 57% done, ETA 00:00:15 (batch 57% done, ETA 00:00:15)
 Auction.House.E03 58% done, ETA 00:00:14 (batch 58% done, ETA 00:00:14)
 Auction.House.E03 59% done, ETA 00:00:14 (batch 59% done, ETA 00:00:14)
 Auction.House.E03 60% done, ETA 00:00:13 (batch 60% done, ETA 00:00:13)
 Auction.House.E03 61% done, ETA 00:00:13 (batch 61% done, ETA 00:00:13)
 Auction.House.E03 62% done, ETA 00:00:12 (batch 62% done, ETA 00:00:12)
 Auction.House.E03 63% done, ETA 00:00:12 (batch 63% done, ETA 00:00:12)
 Auction.House.E03 64% done, ETA 00:00:12 (batch 64% done, ETA 00:00:12)
 Auction.House.E03 65% done, ETA 00:00:11 (batch 65% done, ETA 00:00:11)
 Auction.House.E03 66% done, ETA 00:00:11 (batch 66% done, ETA 00:00:11)
 Auction.House.E03 67% done, ETA 00:00:10 (batch 67% done, ETA 00:00:10)
 Auction.House.E03 68% done, ETA 00:00:10 (batch 68% done, ETA 00:00:10)
 Auction.House.E03 69% done, ETA 00:00:09 (batch 69% done, ETA 00:00:09)
 Auction.House.E03 70% done, ETA 00:00:09 (batch 70% done, ETA 00:00:09)
 Auction.House.E03 71% done, ETA 00:00:09 (batch 71% done, ETA 00:00:09)
 Auction.House.E03 72% done, ETA 00:00:09 (batch 72% done, ETA 00:00:09)
 Auction.House.E03 73% done, ETA 00:00:08 (batch 73% done, ETA 00:00:08)
 Auction.House.E03 74% done, ETA 00:00:08 (batch 74% done, ETA 00:00:08)
 Auction.House.E03 75% done, ETA 00:00:07 (batch 75% done, ETA 00:00:07)
 Auction.House.E03 76% done, ETA 00:00:07 (batch 76% done, ETA 00:00:07)
 Auction.House.E03 77% done, ETA 00:00:07 (batch 77% done, ETA 00:00:07)
 Auction.House.E03 78% done, ETA 00:00:06 (batch 78% done, ETA 00:00:06)
 Auction.House.E03 79% done, ETA 00:00:06 (batch 79% done, ETA 00:00:06)
 Auction.House.E03 80% done, ETA 00:00:06 (batch 80% done, ETA 00:00:06)
 Auction.House.E03 81% done, ETA 00:00:05 (batch 81% done, ETA 00:00:05)
 Auction.House.E03 82% done, ETA 00:00:05 (batch 82% done, ETA 00:00:05)
 Auction.House.E03 83% done, ETA 00:00:05 (batch 83% done, ETA 00:00:05)
 Auction.House.E03 84% done, ETA 00:00:04 (batch 84% done, ETA 00:00:04)
 Auction.House.E03 85% done, ETA 00:00:04 (batch 85% done, ETA 00:00:04)
 Auction.House.E03 86% done, ETA 00:00:04 (batch 86% done, ETA 00:00:04)
 Auction.House.E03 87% done, ETA 00:00:04 (batch 87% done, ETA 00:00:04)
 Auction.House.E03 88% done, ETA 00:00:03 (batch 88% done, ETA 00:00:03)
 Auction.House.E03 89% done, ETA 00:00:03 (batch 89% done, ETA 00:00:03)
 Auction.House.E03 90% done, ETA 00:00:03 (batch 90% done, ETA 00:00:03)
 Auction.House.E03 91% done, ETA 00:00:02 (batch 91% done, ETA 00:00:02)
 Auction.House.E03 92% done, ETA 00:00:02 (batch 92% done, ETA 00:00:02)
 Auction.House.E03 93% done, ETA 00:00:02 (batch 93% done, ETA 00:00:02)
 Auction.House.E03 94% done, ETA 00:00:02 (batch 94% done, ETA 00:00:02)
 Auction.House.E03 95% done, ETA 00:00:01 (batch 95% done, ETA 00:00:01)
 Auction.House.E03 96% done, ETA 00:00:01 (batch 96% done, ETA 00:00:01)
 Auction.House.E03 97% done, ETA 00:00:01 (batch 97% done, ETA 00:00:01)
 Auction.House.E03 98% done, ETA 00:00:01 (batch 98% done, ETA 00:00:01)
 Auction.House.E03 99% done, ETA 00:00:00 (batch 99% done, ETA 00:00:00)
 Auction.House.E03 100% done, ETA 00:00:00 (batch 100% done, ETA 00:00:00)
 Applying adjustment of -2.73dB to /Users/kk/Movies/Azureus/Auction.House.E03.avi.ff.wav...
 Auction.House.E03 2% done, ETA 00:00:49 (batch 2% done, ETA 00:00:49)
 Auction.House.E03 4% done, ETA 00:00:48 (batch 4% done, ETA 00:00:48)
 Auction.House.E03 6% done, ETA 00:00:47 (batch 6% done, ETA 00:00:47)
 Auction.House.E03 7% done, ETA 00:00:40 (batch 7% done, ETA 00:00:40)
 Auction.House.E03 8% done, ETA 00:00:46 (batch 8% done, ETA 00:00:46)
 Auction.House.E03 9% done, ETA 00:00:40 (batch 9% done, ETA 00:00:40)
 Auction.House.E03 10% done, ETA 00:00:45 (batch 10% done, ETA 00:00:45)
 Auction.House.E03 11% done, ETA 00:00:40 (batch 11% done, ETA 00:00:40)
 Auction.House.E03 12% done, ETA 00:00:44 (batch 12% done, ETA 00:00:44)
 Auction.House.E03 13% done, ETA 00:00:40 (batch 13% done, ETA 00:00:40)
 Auction.House.E03 14% done, ETA 00:00:43 (batch 14% done, ETA 00:00:43)
 Auction.House.E03 15% done, ETA 00:00:40 (batch 15% done, ETA 00:00:40)
 Auction.House.E03 16% done, ETA 00:00:42 (batch 16% done, ETA 00:00:42)
 Auction.House.E03 17% done, ETA 00:00:39 (batch 17% done, ETA 00:00:39)
 Auction.House.E03 18% done, ETA 00:00:41 (batch 18% done, ETA 00:00:41)
 Auction.House.E03 19% done, ETA 00:00:38 (batch 19% done, ETA 00:00:38)
 Auction.House.E03 20% done, ETA 00:00:36 (batch 20% done, ETA 00:00:36)
 Auction.House.E03 21% done, ETA 00:00:38 (batch 21% done, ETA 00:00:38)
 Auction.House.E03 22% done, ETA 00:00:35 (batch 22% done, ETA 00:00:35)
 Auction.House.E03 23% done, ETA 00:00:37 (batch 23% done, ETA 00:00:37)
 Auction.House.E03 24% done, ETA 00:00:35 (batch 24% done, ETA 00:00:35)
 Auction.House.E03 25% done, ETA 00:00:33 (batch 25% done, ETA 00:00:33)
 Auction.House.E03 26% done, ETA 00:00:34 (batch 26% done, ETA 00:00:34)
 Auction.House.E03 27% done, ETA 00:00:32 (batch 27% done, ETA 00:00:32)
 Auction.House.E03 28% done, ETA 00:00:33 (batch 28% done, ETA 00:00:33)
 Auction.House.E03 29% done, ETA 00:00:32 (batch 29% done, ETA 00:00:32)
 Auction.House.E03 30% done, ETA 00:00:33 (batch 30% done, ETA 00:00:33)
 Auction.House.E03 31% done, ETA 00:00:31 (batch 31% done, ETA 00:00:31)
 Auction.House.E03 32% done, ETA 00:00:30 (batch 32% done, ETA 00:00:30)
 Auction.House.E03 33% done, ETA 00:00:30 (batch 33% done, ETA 00:00:30)
 Auction.House.E03 34% done, ETA 00:00:29 (batch 34% done, ETA 00:00:29)
 Auction.House.E03 35% done, ETA 00:00:30 (batch 35% done, ETA 00:00:30)
 Auction.House.E03 36% done, ETA 00:00:28 (batch 36% done, ETA 00:00:28)
 Auction.House.E03 39% done, ETA 00:00:28 (batch 39% done, ETA 00:00:28)
 Auction.House.E03 40% done, ETA 00:00:27 (batch 40% done, ETA 00:00:27)
 Auction.House.E03 42% done, ETA 00:00:26 (batch 42% done, ETA 00:00:26)
 Auction.House.E03 43% done, ETA 00:00:25 (batch 43% done, ETA 00:00:25)
 Auction.House.E03 44% done, ETA 00:00:25 (batch 44% done, ETA 00:00:25)
 Auction.House.E03 45% done, ETA 00:00:24 (batch 45% done, ETA 00:00:24)
 Auction.House.E03 46% done, ETA 00:00:25 (batch 46% done, ETA 00:00:25)
 Auction.House.E03 47% done, ETA 00:00:24 (batch 47% done, ETA 00:00:24)
 Auction.House.E03 48% done, ETA 00:00:23 (batch 48% done, ETA 00:00:23)
 Auction.House.E03 49% done, ETA 00:00:23 (batch 49% done, ETA 00:00:23)
 Auction.House.E03 50% done, ETA 00:00:22 (batch 50% done, ETA 00:00:22)
 Auction.House.E03 51% done, ETA 00:00:22 (batch 51% done, ETA 00:00:22)
 Auction.House.E03 52% done, ETA 00:00:21 (batch 52% done, ETA 00:00:21)
 Auction.House.E03 53% done, ETA 00:00:20 (batch 53% done, ETA 00:00:20)
 Auction.House.E03 54% done, ETA 00:00:20 (batch 54% done, ETA 00:00:20)
 Auction.House.E03 55% done, ETA 00:00:20 (batch 55% done, ETA 00:00:20)
 Auction.House.E03 56% done, ETA 00:00:20 (batch 56% done, ETA 00:00:20)
 Auction.House.E03 57% done, ETA 00:00:19 (batch 57% done, ETA 00:00:19)
 Auction.House.E03 58% done, ETA 00:00:18 (batch 58% done, ETA 00:00:18)
 Auction.House.E03 59% done, ETA 00:00:18 (batch 59% done, ETA 00:00:18)
 Auction.House.E03 60% done, ETA 00:00:18 (batch 60% done, ETA 00:00:18)
 Auction.House.E03 61% done, ETA 00:00:17 (batch 61% done, ETA 00:00:17)
 Auction.House.E03 62% done, ETA 00:00:17 (batch 62% done, ETA 00:00:17)
 Auction.House.E03 63% done, ETA 00:00:16 (batch 63% done, ETA 00:00:16)
 Auction.House.E03 64% done, ETA 00:00:16 (batch 64% done, ETA 00:00:16)
 Auction.House.E03 65% done, ETA 00:00:16 (batch 65% done, ETA 00:00:16)
 Auction.House.E03 66% done, ETA 00:00:15 (batch 66% done, ETA 00:00:15)
 Auction.House.E03 67% done, ETA 00:00:15 (batch 67% done, ETA 00:00:15)
 Auction.House.E03 68% done, ETA 00:00:14 (batch 68% done, ETA 00:00:14)
 Auction.House.E03 69% done, ETA 00:00:14 (batch 69% done, ETA 00:00:14)
 Auction.House.E03 70% done, ETA 00:00:13 (batch 70% done, ETA 00:00:13)
 Auction.House.E03 71% done, ETA 00:00:13 (batch 71% done, ETA 00:00:13)
 Auction.House.E03 72% done, ETA 00:00:12 (batch 72% done, ETA 00:00:12)
 Auction.House.E03 73% done, ETA 00:00:12 (batch 73% done, ETA 00:00:12)
 Auction.House.E03 74% done, ETA 00:00:12 (batch 74% done, ETA 00:00:12)
 Auction.House.E03 75% done, ETA 00:00:11 (batch 75% done, ETA 00:00:11)
 Auction.House.E03 76% done, ETA 00:00:11 (batch 76% done, ETA 00:00:11)
 Auction.House.E03 77% done, ETA 00:00:10 (batch 77% done, ETA 00:00:10)
 Auction.House.E03 78% done, ETA 00:00:10 (batch 78% done, ETA 00:00:10)
 Auction.House.E03 79% done, ETA 00:00:09 (batch 79% done, ETA 00:00:09)
 Auction.House.E03 80% done, ETA 00:00:09 (batch 80% done, ETA 00:00:09)
 Auction.House.E03 81% done, ETA 00:00:08 (batch 81% done, ETA 00:00:08)
 Auction.House.E03 82% done, ETA 00:00:08 (batch 82% done, ETA 00:00:08)
 Auction.House.E03 83% done, ETA 00:00:08 (batch 83% done, ETA 00:00:08)
 Auction.House.E03 84% done, ETA 00:00:07 (batch 84% done, ETA 00:00:07)
 Auction.House.E03 85% done, ETA 00:00:07 (batch 85% done, ETA 00:00:07)
 Auction.House.E03 86% done, ETA 00:00:06 (batch 86% done, ETA 00:00:06)
 Auction.House.E03 87% done, ETA 00:00:06 (batch 87% done, ETA 00:00:06)
 Auction.House.E03 88% done, ETA 00:00:05 (batch 88% done, ETA 00:00:05)
 Auction.House.E03 89% done, ETA 00:00:05 (batch 89% done, ETA 00:00:05)
 Auction.House.E03 90% done, ETA 00:00:04 (batch 90% done, ETA 00:00:04)
 Auction.House.E03 91% done, ETA 00:00:04 (batch 91% done, ETA 00:00:04)
 Auction.House.E03 92% done, ETA 00:00:04 (batch 92% done, ETA 00:00:04)
 Auction.House.E03 93% done, ETA 00:00:03 (batch 93% done, ETA 00:00:03)
 Auction.House.E03 94% done, ETA 00:00:03 (batch 94% done, ETA 00:00:03)
 Auction.House.E03 95% done, ETA 00:00:02 (batch 95% done, ETA 00:00:02)
 Auction.House.E03 96% done, ETA 00:00:02 (batch 96% done, ETA 00:00:02)
 ffmpeg version CVS, build 3211265, Copyright (c) 2000-2004 Fabrice Bellard
 configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
 built on Aug 14 2005 14:46:34, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
 Input #0, wav, from '/Users/kk/Movies/Azureus/Auction.House.E03.avi.ff.wav':
 Duration: 01:02:52.5, start: 0.000000, bitrate: 1535 kb/s
 Stream #0.0: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
 Output #0, ac3, to '/Users/kk/Movies/Azureus/Auction.House.E03.avi.ff.ac3':
 Stream #0.0: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
 Stream mapping:
 Stream #0.0 -> #0.0
 Press [q] to stop encoding
 size= 261kB time=4.8 bitrate= 448.0kbits/s
 size= 528kB time=9.7 bitrate= 448.0kbits/s
 size= 756kB time=13.8 bitrate= 448.0kbits/s
 size= 1022kB time=18.7 bitrate= 448.0kbits/s
 size= 1253kB time=22.9 bitrate= 448.0kbits/s
 size= 1510kB time=27.6 bitrate= 448.0kbits/s
 size= 1726kB time=31.6 bitrate= 448.0kbits/s
 size= 1983kB time=36.3 bitrate= 448.0kbits/s
 size= 2210kB time=40.4 bitrate= 448.0kbits/s
 size= 2483kB time=45.4 bitrate= 448.0kbits/s
 size= 2720kB time=49.7 bitrate= 448.0kbits/s
 size= 2986kB time=54.6 bitrate= 448.0kbits/s
 size= 3213kB time=58.8 bitrate= 448.0kbits/s
 size= 3468kB time=63.4 bitrate= 448.0kbits/s
 size= 3678kB time=67.3 bitrate= 448.0kbits/s
 size= 3932kB time=71.9 bitrate= 448.0kbits/s
 size= 4160kB time=76.1 bitrate= 448.0kbits/s
 size= 4391kB time=80.3 bitrate= 448.0kbits/s
 size= 4615kB time=84.4 bitrate= 448.0kbits/s
 size= 4862kB time=88.9 bitrate= 448.0kbits/s
 size= 5080kB time=92.9 bitrate= 448.0kbits/s
 size= 5329kB time=97.4 bitrate= 448.0kbits/s
 size= 5542kB time=101.3 bitrate= 448.0kbits/s
 size= 5808kB time=106.2 bitrate= 448.0kbits/s
 size= 6055kB time=110.7 bitrate= 448.0kbits/s
 size= 6326kB time=115.7 bitrate= 448.0kbits/s
 size= 6556kB time=119.9 bitrate= 448.0kbits/s
 size= 6825kB time=124.8 bitrate= 448.0kbits/s
 size= 6934kB time=126.8 bitrate= 448.0kbits/s
 size= 7201kB time=131.7 bitrate= 448.0kbits/s
 size= 7424kB time=135.7 bitrate= 448.0kbits/s
 size= 7700kB time=140.8 bitrate= 448.0kbits/s
 size= 7943kB time=145.2 bitrate= 448.0kbits/s
 size= 8227kB time=150.4 bitrate= 448.0kbits/s
 size= 8475kB time=155.0 bitrate= 448.0kbits/s
 size= 8754kB time=160.1 bitrate= 448.0kbits/s
 size= 8993kB time=164.4 bitrate= 448.0kbits/s
 size= 9247kB time=169.1 bitrate= 448.0kbits/s
 size= 9459kB time=173.0 bitrate= 448.0kbits/s
 size= 9725kB time=177.8 bitrate= 448.0kbits/s
 size= 9966kB time=182.2 bitrate= 448.0kbits/s
 size= 10110kB time=184.9 bitrate= 448.0kbits/s
 size= 10390kB time=190.0 bitrate= 448.0kbits/s
 size= 10621kB time=194.2 bitrate= 448.0kbits/s
 size= 10885kB time=199.0 bitrate= 448.0kbits/s
 size= 11102kB time=203.0 bitrate= 448.0kbits/s
 size= 11378kB time=208.1 bitrate= 448.0kbits/s
 size= 11624kB time=212.5 bitrate= 448.0kbits/s
 size= 11886kB time=217.3 bitrate= 448.0kbits/s
 size= 12117kB time=221.6 bitrate= 448.0kbits/s
 size= 12388kB time=226.5 bitrate= 448.0kbits/s
 size= 12619kB time=230.8 bitrate= 448.0kbits/s
 size= 12882kB time=235.6 bitrate= 448.0kbits/s
 size= 13104kB time=239.6 bitrate= 448.0kbits/s
 size= 13377kB time=244.6 bitrate= 448.0kbits/s
 size= 13601kB time=248.7 bitrate= 448.0kbits/s
 size= 13869kB time=253.6 bitrate= 448.0kbits/s
 size= 14093kB time=257.7 bitrate= 448.0kbits/s
 size= 14355kB time=262.5 bitrate= 448.0kbits/s
 size= 14581kB time=266.6 bitrate= 448.0kbits/s
 size= 14842kB time=271.4 bitrate= 448.0kbits/s
 size= 15054kB time=275.3 bitrate= 448.0kbits/s
 size= 15311kB time=280.0 bitrate= 448.0kbits/s
 size= 15538kB time=284.1 bitrate= 448.0kbits/s
 size= 15806kB time=289.0 bitrate= 448.0kbits/s
 size= 16039kB time=293.3 bitrate= 448.0kbits/s
 size= 16305kB time=298.1 bitrate= 448.0kbits/s
 size= 16541kB time=302.5 bitrate= 448.0kbits/s
 size= 16816kB time=307.5 bitrate= 448.0kbits/s
 size= 17024kB time=311.3 bitrate= 448.0kbits/s
 size= 17286kB time=316.1 bitrate= 448.0kbits/s
 size= 17510kB time=320.2 bitrate= 448.0kbits/s
 size= 17773kB time=325.0 bitrate= 448.0kbits/s
 size= 18000kB time=329.2 bitrate= 448.0kbits/s
 size= 18279kB time=334.2 bitrate= 448.0kbits/s
 size= 18524kB time=338.7 bitrate= 448.0kbits/s
 size= 18797kB time=343.7 bitrate= 448.0kbits/s
 size= 19008kB time=347.6 bitrate= 448.0kbits/s
 size= 19285kB time=352.6 bitrate= 448.0kbits/s
 size= 19511kB time=356.8 bitrate= 448.0kbits/s
 size= 19786kB time=361.8 bitrate= 448.0kbits/s
 size= 20018kB time=366.0 bitrate= 448.0kbits/s
 size= 20290kB time=371.0 bitrate= 448.0kbits/s
 size= 20533kB time=375.5 bitrate= 448.0kbits/s
 size= 20809kB time=380.5 bitrate= 448.0kbits/s
 size= 21024kB time=384.4 bitrate= 448.0kbits/s
 size= 21282kB time=389.2 bitrate= 448.0kbits/s
 size= 21500kB time=393.2 bitrate= 448.0kbits/s
 size= 21700kB time=396.8 bitrate= 448.0kbits/s
 size= 21929kB time=401.0 bitrate= 448.0kbits/s
 size= 22200kB time=406.0 bitrate= 448.0kbits/s
 size= 22430kB time=410.1 bitrate= 448.0kbits/s
 size= 22685kB time=414.8 bitrate= 448.0kbits/s
 size= 22908kB time=418.9 bitrate= 448.0kbits/s
 size= 23177kB time=423.8 bitrate= 448.0kbits/s
 size= 23413kB time=428.1 bitrate= 448.0kbits/s
 size= 23678kB time=433.0 bitrate= 448.0kbits/s
 size= 23907kB time=437.2 bitrate= 448.0kbits/s
 size= 24169kB time=442.0 bitrate= 448.0kbits/s
 size= 24379kB time=445.8 bitrate= 448.0kbits/s
 size= 24633kB time=450.4 bitrate= 448.0kbits/s
 size= 24810kB time=453.7 bitrate= 448.0kbits/s
 size= 25070kB time=458.4 bitrate= 448.0kbits/s
 size= 25296kB time=462.6 bitrate= 448.0kbits/s
 size= 25546kB time=467.1 bitrate= 448.0kbits/s
 size= 25767kB time=471.2 bitrate= 448.0kbits/s
 size= 26019kB time=475.8 bitrate= 448.0kbits/s
 size= 26240kB time=479.8 bitrate= 448.0kbits/s
 size= 26486kB time=484.3 bitrate= 448.0kbits/s
 size= 26694kB time=488.1 bitrate= 448.0kbits/s
 size= 26945kB time=492.7 bitrate= 448.0kbits/s
 size= 27146kB time=496.4 bitrate= 448.0kbits/s
 size= 27394kB time=500.9 bitrate= 448.0kbits/s
 size= 27618kB time=505.0 bitrate= 448.0kbits/s
 size= 27867kB time=509.6 bitrate= 448.0kbits/s
 size= 28082kB time=513.5 bitrate= 448.0kbits/s
 size= 28327kB time=518.0 bitrate= 448.0kbits/s
 size= 28523kB time=521.6 bitrate= 448.0kbits/s
 size= 28772kB time=526.1 bitrate= 448.0kbits/s
 size= 28975kB time=529.8 bitrate= 448.0kbits/s
 size= 29230kB time=534.5 bitrate= 448.0kbits/s
 size= 29452kB time=538.6 bitrate= 448.0kbits/s
 size= 29706kB time=543.2 bitrate= 448.0kbits/s
 size= 29922kB time=547.1 bitrate= 448.0kbits/s
 size= 30175kB time=551.8 bitrate= 448.0kbits/s
 size= 30380kB time=555.5 bitrate= 448.0kbits/s
 size= 30637kB time=560.2 bitrate= 448.0kbits/s
 size= 30863kB time=564.4 bitrate= 448.0kbits/s
 size= 31124kB time=569.1 bitrate= 448.0kbits/s
 size= 31351kB time=573.3 bitrate= 448.0kbits/s
 size= 31621kB time=578.2 bitrate= 448.0kbits/s
 size= 31850kB time=582.4 bitrate= 448.0kbits/s
 size= 32116kB time=587.3 bitrate= 448.0kbits/s
 size= 32331kB time=591.2 bitrate= 448.0kbits/s
 size= 32568kB time=595.5 bitrate= 448.0kbits/s
 size= 32770kB time=599.2 bitrate= 448.0kbits/s
 size= 33017kB time=603.7 bitrate= 448.0kbits/s
 size= 33240kB time=607.8 bitrate= 448.0kbits/s
 size= 33504kB time=612.6 bitrate= 448.0kbits/s
 size= 33721kB time=616.6 bitrate= 448.0kbits/s
 size= 33983kB time=621.4 bitrate= 448.0kbits/s
 size= 34206kB time=625.5 bitrate= 448.0kbits/s
 size= 34459kB time=630.1 bitrate= 448.0kbits/s
 size= 34699kB time=634.5 bitrate= 448.0kbits/s
 size= 34951kB time=639.1 bitrate= 448.0kbits/s
 size= 35178kB time=643.3 bitrate= 448.0kbits/s
 size= 35436kB time=648.0 bitrate= 448.0kbits/s
 size= 35630kB time=651.5 bitrate= 448.0kbits/s
 size= 35864kB time=655.8 bitrate= 448.0kbits/s
 size= 36088kB time=659.9 bitrate= 448.0kbits/s
 size= 36351kB time=664.7 bitrate= 448.0kbits/s
 size= 36580kB time=668.9 bitrate= 448.0kbits/s
 size= 36830kB time=673.5 bitrate= 448.0kbits/s
 size= 37046kB time=677.4 bitrate= 448.0kbits/s
 size= 37301kB time=682.1 bitrate= 448.0kbits/s
 size= 37524kB time=686.1 bitrate= 448.0kbits/s
 size= 37767kB time=690.6 bitrate= 448.0kbits/s
 size= 37975kB time=694.4 bitrate= 448.0kbits/s
 size= 38229kB time=699.0 bitrate= 448.0kbits/s
 size= 38491kB time=703.8 bitrate= 448.0kbits/s
 size= 38710kB time=707.8 bitrate= 448.0kbits/s
 size= 38981kB time=712.8 bitrate= 448.0kbits/s
 size= 39212kB time=717.0 bitrate= 448.0kbits/s
 size= 39468kB time=721.7 bitrate= 448.0kbits/s
 size= 39657kB time=725.2 bitrate= 448.0kbits/s
 size= 39893kB time=729.5 bitrate= 448.0kbits/s
 size= 40110kB time=733.4 bitrate= 448.0kbits/s
 size= 40371kB time=738.2 bitrate= 448.0kbits/s
 size= 40590kB time=742.2 bitrate= 448.0kbits/s
 size= 40856kB time=747.1 bitrate= 448.0kbits/s
 size= 41053kB time=750.7 bitrate= 448.0kbits/s
 size= 41293kB time=755.1 bitrate= 448.0kbits/s
 size= 41554kB time=759.8 bitrate= 448.0kbits/s
 size= 41771kB time=763.8 bitrate= 448.0kbits/s
 size= 42037kB time=768.7 bitrate= 448.0kbits/s
 size= 42261kB time=772.8 bitrate= 448.0kbits/s
 size= 42520kB time=777.5 bitrate= 448.0kbits/s
 size= 42740kB time=781.5 bitrate= 448.0kbits/s
 size= 43004kB time=786.4 bitrate= 448.0kbits/s
 size= 43220kB time=790.3 bitrate= 448.0kbits/s
 size= 43486kB time=795.2 bitrate= 448.0kbits/s
 size= 43708kB time=799.2 bitrate= 448.0kbits/s
 size= 43972kB time=804.1 bitrate= 448.0kbits/s
 size= 44203kB time=808.3 bitrate= 448.0kbits/s
 size= 44464kB time=813.1 bitrate= 448.0kbits/s
 size= 44693kB time=817.2 bitrate= 448.0kbits/s
 size= 44964kB time=822.2 bitrate= 448.0kbits/s
 size= 45187kB time=826.3 bitrate= 448.0kbits/s
 size= 45454kB time=831.2 bitrate= 448.0kbits/s
 size= 45673kB time=835.2 bitrate= 448.0kbits/s
 size= 45938kB time=840.0 bitrate= 448.0kbits/s
 size= 46174kB time=844.3 bitrate= 448.0kbits/s
 size= 46447kB time=849.3 bitrate= 448.0kbits/s
 size= 46667kB time=853.3 bitrate= 448.0kbits/s
 size= 46926kB time=858.1 bitrate= 448.0kbits/s
 size= 47159kB time=862.3 bitrate= 448.0kbits/s
 size= 47422kB time=867.1 bitrate= 448.0kbits/s
 size= 47656kB time=871.4 bitrate= 448.0kbits/s
 size= 47908kB time=876.0 bitrate= 448.0kbits/s
 size= 48134kB time=880.2 bitrate= 448.0kbits/s
 size= 48396kB time=885.0 bitrate= 448.0kbits/s
 size= 48626kB time=889.2 bitrate= 448.0kbits/s
 size= 48881kB time=893.8 bitrate= 448.0kbits/s
 size= 49075kB time=897.4 bitrate= 448.0kbits/s
 size= 49332kB time=902.1 bitrate= 448.0kbits/s
 size= 49560kB time=906.2 bitrate= 448.0kbits/s
 size= 49793kB time=910.5 bitrate= 448.0kbits/s
 size= 50062kB time=915.4 bitrate= 448.0kbits/s
 size= 50312kB time=920.0 bitrate= 448.0kbits/s
 size= 50542kB time=924.2 bitrate= 448.0kbits/s
 size= 50804kB time=929.0 bitrate= 448.0kbits/s
 size= 51037kB time=933.2 bitrate= 448.0kbits/s
 size= 51312kB time=938.3 bitrate= 448.0kbits/s
 size= 51548kB time=942.6 bitrate= 448.0kbits/s
 size= 51812kB time=947.4 bitrate= 448.0kbits/s
 size= 52033kB time=951.5 bitrate= 448.0kbits/s
 size= 52292kB time=956.2 bitrate= 448.0kbits/s
 size= 52507kB time=960.1 bitrate= 448.0kbits/s
 size= 52764kB time=964.8 bitrate= 448.0kbits/s
 size= 52967kB time=968.5 bitrate= 448.0kbits/s
 size= 53237kB time=973.5 bitrate= 448.0kbits/s
 size= 53475kB time=977.8 bitrate= 448.0kbits/s
 size= 53736kB time=982.6 bitrate= 448.0kbits/s
 size= 53965kB time=986.8 bitrate= 448.0kbits/s
 size= 54238kB time=991.8 bitrate= 448.0kbits/s
 size= 54469kB time=996.0 bitrate= 448.0kbits/s
 size= 54730kB time=1000.8 bitrate= 448.0kbits/s
 size= 54955kB time=1004.9 bitrate= 448.0kbits/s
 size= 55228kB time=1009.9 bitrate= 448.0kbits/s
 size= 55473kB time=1014.4 bitrate= 448.0kbits/s
 size= 55739kB time=1019.2 bitrate= 448.0kbits/s
 size= 55976kB time=1023.6 bitrate= 448.0kbits/s
 size= 56245kB time=1028.5 bitrate= 448.0kbits/s
 size= 56476kB time=1032.7 bitrate= 448.0kbits/s
 size= 56730kB time=1037.3 bitrate= 448.0kbits/s
 size= 56950kB time=1041.4 bitrate= 448.0kbits/s
 size= 57216kB time=1046.2 bitrate= 448.0kbits/s
 size= 57438kB time=1050.3 bitrate= 448.0kbits/s
 size= 57664kB time=1054.4 bitrate= 448.0kbits/s
 size= 57956kB time=1059.8 bitrate= 448.0kbits/s
 size= 58203kB time=1064.3 bitrate= 448.0kbits/s
 size= 58480kB time=1069.3 bitrate= 448.0kbits/s
 size= 58698kB time=1073.3 bitrate= 448.0kbits/s
 size= 58977kB time=1078.4 bitrate= 448.0kbits/s
 size= 59204kB time=1082.6 bitrate= 448.0kbits/s
 size= 59465kB time=1087.4 bitrate= 448.0kbits/s
 size= 59689kB time=1091.5 bitrate= 448.0kbits/s
 size= 59964kB time=1096.5 bitrate= 448.0kbits/s
 size= 60204kB time=1100.9 bitrate= 448.0kbits/s
 size= 60475kB time=1105.8 bitrate= 448.0kbits/s
 size= 60692kB time=1109.8 bitrate= 448.0kbits/s
 size= 60956kB time=1114.6 bitrate= 448.0kbits/s
 size= 61204kB time=1119.2 bitrate= 448.0kbits/s
 size= 61481kB time=1124.2 bitrate= 448.0kbits/s
 size= 61698kB time=1128.2 bitrate= 448.0kbits/s
 size= 61945kB time=1132.7 bitrate= 448.0kbits/s
 size= 62167kB time=1136.8 bitrate= 448.0kbits/s
 size= 62435kB time=1141.7 bitrate= 448.0kbits/s
 size= 62646kB time=1145.5 bitrate= 448.0kbits/s
 size= 62912kB time=1150.4 bitrate= 448.0kbits/s
 size= 63149kB time=1154.7 bitrate= 448.0kbits/s
 size= 63422kB time=1159.7 bitrate= 448.0kbits/s
 size= 63654kB time=1164.0 bitrate= 448.0kbits/s
 size= 63933kB time=1169.1 bitrate= 448.0kbits/s
 size= 64160kB time=1173.2 bitrate= 448.0kbits/s
 size= 64418kB time=1177.9 bitrate= 448.0kbits/s
 size= 64530kB time=1180.0 bitrate= 448.0kbits/s
 size= 64799kB time=1184.9 bitrate= 448.0kbits/s
 size= 65037kB time=1189.2 bitrate= 448.0kbits/s
 size= 65305kB time=1194.1 bitrate= 448.0kbits/s
 size= 65525kB time=1198.2 bitrate= 448.0kbits/s
 size= 65796kB time=1203.1 bitrate= 448.0kbits/s
 size= 66029kB time=1207.4 bitrate= 448.0kbits/s
 size= 66295kB time=1212.3 bitrate= 448.0kbits/s
 size= 66514kB time=1216.3 bitrate= 448.0kbits/s
 size= 66775kB time=1221.0 bitrate= 448.0kbits/s
 size= 66986kB time=1224.9 bitrate= 448.0kbits/s
 size= 67249kB time=1229.7 bitrate= 448.0kbits/s
 size= 67490kB time=1234.1 bitrate= 448.0kbits/s
 size= 67762kB time=1239.1 bitrate= 448.0kbits/s
 size= 68007kB time=1243.6 bitrate= 448.0kbits/s
 size= 68266kB time=1248.3 bitrate= 448.0kbits/s
 size= 68469kB time=1252.0 bitrate= 448.0kbits/s
 size= 68735kB time=1256.9 bitrate= 448.0kbits/s
 size= 68957kB time=1260.9 bitrate= 448.0kbits/s
 size= 69211kB time=1265.6 bitrate= 448.0kbits/s
 size= 69430kB time=1269.6 bitrate= 448.0kbits/s
 size= 69690kB time=1274.3 bitrate= 448.0kbits/s
 size= 69911kB time=1278.4 bitrate= 448.0kbits/s
 size= 70173kB time=1283.2 bitrate= 448.0kbits/s
 size= 70388kB time=1287.1 bitrate= 448.0kbits/s
 size= 70649kB time=1291.9 bitrate= 448.0kbits/s
 size= 70872kB time=1295.9 bitrate= 448.0kbits/s
 size= 71134kB time=1300.7 bitrate= 448.0kbits/s
 size= 71358kB time=1304.8 bitrate= 448.0kbits/s
 size= 71622kB time=1309.7 bitrate= 448.0kbits/s
 size= 71867kB time=1314.1 bitrate= 448.0kbits/s
 size= 72151kB time=1319.3 bitrate= 448.0kbits/s
 size= 72329kB time=1322.6 bitrate= 448.0kbits/s
 size= 72602kB time=1327.6 bitrate= 448.0kbits/s
 size= 72847kB time=1332.1 bitrate= 448.0kbits/s
 size= 73134kB time=1337.3 bitrate= 448.0kbits/s
 size= 73381kB time=1341.8 bitrate= 448.0kbits/s
 size= 73668kB time=1347.1 bitrate= 448.0kbits/s
 size= 73904kB time=1351.4 bitrate= 448.0kbits/s
 size= 74188kB time=1356.6 bitrate= 448.0kbits/s
 size= 74408kB time=1360.6 bitrate= 448.0kbits/s
 size= 74686kB time=1365.7 bitrate= 448.0kbits/s
 size= 74968kB time=1370.8 bitrate= 448.0kbits/s
 size= 75210kB time=1375.3 bitrate= 448.0kbits/s
 size= 75488kB time=1380.4 bitrate= 448.0kbits/s
 size= 75726kB time=1384.7 bitrate= 448.0kbits/s
 size= 76002kB time=1389.8 bitrate= 448.0kbits/s
 size= 76226kB time=1393.9 bitrate= 448.0kbits/s
 size= 76498kB time=1398.8 bitrate= 448.0kbits/s
 size= 76724kB time=1402.9 bitrate= 448.0kbits/s
 size= 76986kB time=1407.7 bitrate= 448.0kbits/s
 size= 77220kB time=1412.0 bitrate= 448.0kbits/s
 size= 77486kB time=1416.9 bitrate= 448.0kbits/s
 size= 77716kB time=1421.1 bitrate= 448.0kbits/s
 size= 77975kB time=1425.8 bitrate= 448.0kbits/s
 size= 78199kB time=1429.9 bitrate= 448.0kbits/s
 size= 78463kB time=1434.8 bitrate= 448.0kbits/s
 size= 78704kB time=1439.2 bitrate= 448.0kbits/s
 size= 78969kB time=1444.0 bitrate= 448.0kbits/s
 size= 79130kB time=1446.9 bitrate= 448.0kbits/s
 size= 79398kB time=1451.8 bitrate= 448.0kbits/s
 size= 79637kB time=1456.2 bitrate= 448.0kbits/s
 size= 79903kB time=1461.1 bitrate= 448.0kbits/s
 size= 80117kB time=1465.0 bitrate= 448.0kbits/s
 size= 80379kB time=1469.8 bitrate= 448.0kbits/s
 size= 80607kB time=1474.0 bitrate= 448.0kbits/s
 size= 80883kB time=1479.0 bitrate= 448.0kbits/s
 size= 81112kB time=1483.2 bitrate= 448.0kbits/s
 size= 81380kB time=1488.1 bitrate= 448.0kbits/s
 size= 81618kB time=1492.4 bitrate= 448.0kbits/s
 size= 81884kB time=1497.3 bitrate= 448.0kbits/s
 size= 82114kB time=1501.5 bitrate= 448.0kbits/s
 size= 82390kB time=1506.6 bitrate= 448.0kbits/s
 size= 82630kB time=1510.9 bitrate= 448.0kbits/s
 size= 82887kB time=1515.6 bitrate= 448.0kbits/s
 size= 83106kB time=1519.6 bitrate= 448.0kbits/s
 size= 83360kB time=1524.3 bitrate= 448.0kbits/s
 size= 83584kB time=1528.4 bitrate= 448.0kbits/s
 size= 83850kB time=1533.2 bitrate= 448.0kbits/s
 size= 84066kB time=1537.2 bitrate= 448.0kbits/s
 size= 84334kB time=1542.1 bitrate= 448.0kbits/s
 size= 84553kB time=1546.1 bitrate= 448.0kbits/s
 size= 84817kB time=1550.9 bitrate= 448.0kbits/s
 size= 85052kB time=1555.2 bitrate= 448.0kbits/s
 size= 85307kB time=1559.9 bitrate= 448.0kbits/s
 size= 85522kB time=1563.8 bitrate= 448.0kbits/s
 size= 85776kB time=1568.5 bitrate= 448.0kbits/s
 size= 85993kB time=1572.4 bitrate= 448.0kbits/s
 size= 86264kB time=1577.4 bitrate= 448.0kbits/s
 size= 86485kB time=1581.4 bitrate= 448.0kbits/s
 size= 86739kB time=1586.1 bitrate= 448.0kbits/s
 size= 86964kB time=1590.2 bitrate= 448.0kbits/s
 size= 87238kB time=1595.2 bitrate= 448.0kbits/s
 size= 87467kB time=1599.4 bitrate= 448.0kbits/s
 size= 87726kB time=1604.1 bitrate= 448.0kbits/s
 size= 87962kB time=1608.4 bitrate= 448.0kbits/s
 size= 88254kB time=1613.8 bitrate= 448.0kbits/s
 size= 88515kB time=1618.6 bitrate= 448.0kbits/s
 size= 88770kB time=1623.2 bitrate= 448.0kbits/s
 size= 88989kB time=1627.2 bitrate= 448.0kbits/s
 size= 89257kB time=1632.1 bitrate= 448.0kbits/s
 size= 89486kB time=1636.3 bitrate= 448.0kbits/s
 size= 89768kB time=1641.5 bitrate= 448.0kbits/s
 size= 89992kB time=1645.6 bitrate= 448.0kbits/s
 size= 90254kB time=1650.4 bitrate= 448.0kbits/s
 size= 90487kB time=1654.6 bitrate= 448.0kbits/s
 size= 90750kB time=1659.4 bitrate= 448.0kbits/s
 size= 90990kB time=1663.8 bitrate= 448.0kbits/s
 size= 91257kB time=1668.7 bitrate= 448.0kbits/s
 size= 91492kB time=1673.0 bitrate= 448.0kbits/s
 size= 91737kB time=1677.5 bitrate= 448.0kbits/s
 size= 92013kB time=1682.5 bitrate= 448.0kbits/s
 size= 92262kB time=1687.1 bitrate= 448.0kbits/s
 size= 92544kB time=1692.2 bitrate= 448.0kbits/s
 size= 92755kB time=1696.1 bitrate= 448.0kbits/s
 size= 93011kB time=1700.8 bitrate= 448.0kbits/s
 size= 93228kB time=1704.7 bitrate= 448.0kbits/s
 size= 93488kB time=1709.5 bitrate= 448.0kbits/s
 size= 93662kB time=1712.7 bitrate= 448.0kbits/s
 size= 93926kB time=1717.5 bitrate= 448.0kbits/s
 size= 94173kB time=1722.0 bitrate= 448.0kbits/s
 size= 94439kB time=1726.9 bitrate= 448.0kbits/s
 size= 94663kB time=1731.0 bitrate= 448.0kbits/s
 size= 94924kB time=1735.7 bitrate= 448.0kbits/s
 size= 95153kB time=1739.9 bitrate= 448.0kbits/s
 size= 95415kB time=1744.7 bitrate= 448.0kbits/s
 size= 95636kB time=1748.8 bitrate= 448.0kbits/s
 size= 95909kB time=1753.8 bitrate= 448.0kbits/s
 size= 96133kB time=1757.9 bitrate= 448.0kbits/s
 size= 96406kB time=1762.8 bitrate= 448.0kbits/s
 size= 96638kB time=1767.1 bitrate= 448.0kbits/s
 size= 96910kB time=1772.1 bitrate= 448.0kbits/s
 size= 97139kB time=1776.3 bitrate= 448.0kbits/s
 size= 97382kB time=1780.7 bitrate= 448.0kbits/s
 size= 97575kB time=1784.2 bitrate= 448.0kbits/s
 size= 97834kB time=1789.0 bitrate= 448.0kbits/s
 size= 98049kB time=1792.9 bitrate= 448.0kbits/s
 size= 98304kB time=1797.6 bitrate= 448.0kbits/s
 size= 98528kB time=1801.7 bitrate= 448.0kbits/s
 size= 98800kB time=1806.6 bitrate= 448.0kbits/s
 size= 99013kB time=1810.5 bitrate= 448.0kbits/s
 size= 99276kB time=1815.3 bitrate= 448.0kbits/s
 size= 99474kB time=1818.9 bitrate= 448.0kbits/s
 size= 99738kB time=1823.8 bitrate= 448.0kbits/s
 size= 100016kB time=1828.9 bitrate= 448.0kbits/s
 size= 100249kB time=1833.1 bitrate= 448.0kbits/s
 size= 100518kB time=1838.0 bitrate= 448.0kbits/s
 size= 100744kB time=1842.2 bitrate= 448.0kbits/s
 size= 101020kB time=1847.2 bitrate= 448.0kbits/s
 size= 101239kB time=1851.2 bitrate= 448.0kbits/s
 size= 101516kB time=1856.3 bitrate= 448.0kbits/s
 size= 101752kB time=1860.6 bitrate= 448.0kbits/s
 size= 102022kB time=1865.5 bitrate= 448.0kbits/s
 size= 102249kB time=1869.7 bitrate= 448.0kbits/s
 size= 102510kB time=1874.5 bitrate= 448.0kbits/s
 size= 102741kB time=1878.7 bitrate= 448.0kbits/s
 size= 103008kB time=1883.6 bitrate= 448.0kbits/s
 size= 103234kB time=1887.7 bitrate= 448.0kbits/s
 size= 103498kB time=1892.5 bitrate= 448.0kbits/s
 size= 103730kB time=1896.8 bitrate= 448.0kbits/s
 size= 103990kB time=1901.5 bitrate= 448.0kbits/s
 size= 104216kB time=1905.7 bitrate= 448.0kbits/s
 size= 104477kB time=1910.4 bitrate= 448.0kbits/s
 size= 104696kB time=1914.4 bitrate= 448.0kbits/s
 size= 104951kB time=1919.1 bitrate= 448.0kbits/s
 size= 105158kB time=1922.9 bitrate= 448.0kbits/s
 size= 105418kB time=1927.6 bitrate= 448.0kbits/s
 size= 105651kB time=1931.9 bitrate= 448.0kbits/s
 size= 105892kB time=1936.3 bitrate= 448.0kbits/s
 size= 106110kB time=1940.3 bitrate= 448.0kbits/s
 size= 106169kB time=1941.4 bitrate= 448.0kbits/s
 size= 106391kB time=1945.4 bitrate= 448.0kbits/s
 size= 106645kB time=1950.1 bitrate= 448.0kbits/s
 size= 106866kB time=1954.1 bitrate= 448.0kbits/s
 size= 107124kB time=1958.8 bitrate= 448.0kbits/s
 size= 107350kB time=1963.0 bitrate= 448.0kbits/s
 size= 107604kB time=1967.6 bitrate= 448.0kbits/s
 size= 107826kB time=1971.7 bitrate= 448.0kbits/s
 size= 108008kB time=1975.0 bitrate= 448.0kbits/s
 size= 108227kB time=1979.0 bitrate= 448.0kbits/s
 size= 108498kB time=1984.0 bitrate= 448.0kbits/s
 size= 108720kB time=1988.0 bitrate= 448.0kbits/s
 size= 109004kB time=1993.2 bitrate= 448.0kbits/s
 size= 109244kB time=1997.6 bitrate= 448.0kbits/s
 size= 109515kB time=2002.6 bitrate= 448.0kbits/s
 size= 109742kB time=2006.7 bitrate= 448.0kbits/s
 size= 110007kB time=2011.6 bitrate= 448.0kbits/s
 size= 110229kB time=2015.6 bitrate= 448.0kbits/s
 size= 110486kB time=2020.3 bitrate= 448.0kbits/s
 size= 110700kB time=2024.2 bitrate= 448.0kbits/s
 size= 110969kB time=2029.2 bitrate= 448.0kbits/s
 size= 111197kB time=2033.3 bitrate= 448.0kbits/s
 size= 111470kB time=2038.3 bitrate= 448.0kbits/s
 size= 111704kB time=2042.6 bitrate= 448.0kbits/s
 size= 111982kB time=2047.7 bitrate= 448.0kbits/s
 size= 112219kB time=2052.0 bitrate= 448.0kbits/s
 size= 112490kB time=2057.0 bitrate= 448.0kbits/s
 size= 112698kB time=2060.8 bitrate= 448.0kbits/s
 size= 112982kB time=2066.0 bitrate= 448.0kbits/s
 size= 113208kB time=2070.1 bitrate= 448.0kbits/s
 size= 113489kB time=2075.2 bitrate= 448.0kbits/s
 size= 113713kB time=2079.3 bitrate= 448.0kbits/s
 size= 113992kB time=2084.4 bitrate= 448.0kbits/s
 size= 114240kB time=2089.0 bitrate= 448.0kbits/s
 size= 114516kB time=2094.0 bitrate= 448.0kbits/s
 size= 114744kB time=2098.2 bitrate= 448.0kbits/s
 size= 115014kB time=2103.1 bitrate= 448.0kbits/s
 size= 115244kB time=2107.3 bitrate= 448.0kbits/s
 size= 115524kB time=2112.4 bitrate= 448.0kbits/s
 size= 115775kB time=2117.0 bitrate= 448.0kbits/s
 size= 116050kB time=2122.0 bitrate= 448.0kbits/s
 size= 116289kB time=2126.4 bitrate= 448.0kbits/s
 size= 116566kB time=2131.5 bitrate= 448.0kbits/s
 size= 116804kB time=2135.8 bitrate= 448.0kbits/s
 size= 117089kB time=2141.1 bitrate= 448.0kbits/s
 size= 117330kB time=2145.5 bitrate= 448.0kbits/s
 size= 117605kB time=2150.5 bitrate= 448.0kbits/s
 size= 117854kB time=2155.0 bitrate= 448.0kbits/s
 size= 118148kB time=2160.4 bitrate= 448.0kbits/s
 size= 118394kB time=2164.9 bitrate= 448.0kbits/s
 size= 118671kB time=2170.0 bitrate= 448.0kbits/s
 size= 118895kB time=2174.1 bitrate= 448.0kbits/s
 size= 119166kB time=2179.0 bitrate= 448.0kbits/s
 size= 119385kB time=2183.0 bitrate= 448.0kbits/s
 size= 119653kB time=2187.9 bitrate= 448.0kbits/s
 size= 119870kB time=2191.9 bitrate= 448.0kbits/s
 size= 120132kB time=2196.7 bitrate= 448.0kbits/s
 size= 120351kB time=2200.7 bitrate= 448.0kbits/s
 size= 120605kB time=2205.3 bitrate= 448.0kbits/s
 size= 120829kB time=2209.4 bitrate= 448.0kbits/s
 size= 121086kB time=2214.1 bitrate= 448.0kbits/s
 size= 121319kB time=2218.4 bitrate= 448.0kbits/s
 size= 121595kB time=2223.5 bitrate= 448.0kbits/s
 size= 121842kB time=2228.0 bitrate= 448.0kbits/s
 size= 122131kB time=2233.2 bitrate= 448.0kbits/s
 size= 122365kB time=2237.5 bitrate= 448.0kbits/s
 size= 122617kB time=2242.1 bitrate= 448.0kbits/s
 size= 122838kB time=2246.2 bitrate= 448.0kbits/s
 size= 123036kB time=2249.8 bitrate= 448.0kbits/s
 size= 123279kB time=2254.2 bitrate= 448.0kbits/s
 size= 123562kB time=2259.4 bitrate= 448.0kbits/s
 size= 123800kB time=2263.8 bitrate= 448.0kbits/s
 size= 124084kB time=2269.0 bitrate= 448.0kbits/s
 size= 124318kB time=2273.2 bitrate= 448.0kbits/s
 size= 124590kB time=2278.2 bitrate= 448.0kbits/s
 size= 124820kB time=2282.4 bitrate= 448.0kbits/s
 size= 125104kB time=2287.6 bitrate= 448.0kbits/s
 size= 125352kB time=2292.2 bitrate= 448.0kbits/s
 size= 125624kB time=2297.1 bitrate= 448.0kbits/s
 size= 125678kB time=2298.1 bitrate= 448.0kbits/s
 size= 125972kB time=2303.5 bitrate= 448.0kbits/s
 size= 126220kB time=2308.0 bitrate= 448.0kbits/s
 size= 126495kB time=2313.1 bitrate= 448.0kbits/s
 size= 126702kB time=2316.8 bitrate= 448.0kbits/s
 size= 126984kB time=2322.0 bitrate= 448.0kbits/s
 size= 127213kB time=2326.2 bitrate= 448.0kbits/s
 size= 127484kB time=2331.1 bitrate= 448.0kbits/s
 size= 127701kB time=2335.1 bitrate= 448.0kbits/s
 size= 127990kB time=2340.4 bitrate= 448.0kbits/s
 size= 128236kB time=2344.9 bitrate= 448.0kbits/s
 size= 128516kB time=2350.0 bitrate= 448.0kbits/s
 size= 128753kB time=2354.3 bitrate= 448.0kbits/s
 size= 129040kB time=2359.6 bitrate= 448.0kbits/s
 size= 129286kB time=2364.1 bitrate= 448.0kbits/s
 size= 129563kB time=2369.2 bitrate= 448.0kbits/s
 size= 129812kB time=2373.7 bitrate= 448.0kbits/s
 size= 130097kB time=2378.9 bitrate= 448.0kbits/s
 size= 130342kB time=2383.4 bitrate= 448.0kbits/s
 size= 130630kB time=2388.7 bitrate= 448.0kbits/s
 size= 130853kB time=2392.7 bitrate= 448.0kbits/s
 size= 131140kB time=2398.0 bitrate= 448.0kbits/s
 size= 131371kB time=2402.2 bitrate= 448.0kbits/s
 size= 131656kB time=2407.4 bitrate= 448.0kbits/s
 size= 131904kB time=2412.0 bitrate= 448.0kbits/s
 size= 132183kB time=2417.1 bitrate= 448.0kbits/s
 size= 132428kB time=2421.5 bitrate= 448.0kbits/s
 size= 132701kB time=2426.5 bitrate= 448.0kbits/s
 size= 132921kB time=2430.6 bitrate= 448.0kbits/s
 size= 133198kB time=2435.6 bitrate= 448.0kbits/s
 size= 133427kB time=2439.8 bitrate= 448.0kbits/s
 size= 133698kB time=2444.8 bitrate= 448.0kbits/s
 size= 133926kB time=2448.9 bitrate= 448.0kbits/s
 size= 134199kB time=2453.9 bitrate= 448.0kbits/s
 size= 134432kB time=2458.2 bitrate= 448.0kbits/s
 size= 134706kB time=2463.2 bitrate= 448.0kbits/s
 size= 134920kB time=2467.1 bitrate= 448.0kbits/s
 size= 135177kB time=2471.8 bitrate= 448.0kbits/s
 size= 135406kB time=2476.0 bitrate= 448.0kbits/s
 size= 135660kB time=2480.6 bitrate= 448.0kbits/s
 size= 135889kB time=2484.8 bitrate= 448.0kbits/s
 size= 136154kB time=2489.7 bitrate= 448.0kbits/s
 size= 136388kB time=2494.0 bitrate= 448.0kbits/s
 size= 136652kB time=2498.8 bitrate= 448.0kbits/s
 size= 136883kB time=2503.0 bitrate= 448.0kbits/s
 size= 137160kB time=2508.1 bitrate= 448.0kbits/s
 size= 137405kB time=2512.5 bitrate= 448.0kbits/s
 size= 137681kB time=2517.6 bitrate= 448.0kbits/s
 size= 137921kB time=2522.0 bitrate= 448.0kbits/s
 size= 138117kB time=2525.6 bitrate= 448.0kbits/s
 size= 138353kB time=2529.9 bitrate= 448.0kbits/s
 size= 138628kB time=2534.9 bitrate= 448.0kbits/s
 size= 138854kB time=2539.0 bitrate= 448.0kbits/s
 size= 139139kB time=2544.3 bitrate= 448.0kbits/s
 size= 139388kB time=2548.8 bitrate= 448.0kbits/s
 size= 139673kB time=2554.0 bitrate= 448.0kbits/s
 size= 139914kB time=2558.4 bitrate= 448.0kbits/s
 size= 140198kB time=2563.6 bitrate= 448.0kbits/s
 size= 140441kB time=2568.1 bitrate= 448.0kbits/s
 size= 140723kB time=2573.2 bitrate= 448.0kbits/s
 size= 140956kB time=2577.5 bitrate= 448.0kbits/s
 size= 141232kB time=2582.5 bitrate= 448.0kbits/s
 size= 141475kB time=2587.0 bitrate= 448.0kbits/s
 size= 141760kB time=2592.2 bitrate= 448.0kbits/s
 size= 142014kB time=2596.8 bitrate= 448.0kbits/s
 size= 142314kB time=2602.3 bitrate= 448.0kbits/s
 size= 142560kB time=2606.8 bitrate= 448.0kbits/s
 size= 142844kB time=2612.0 bitrate= 448.0kbits/s
 size= 143078kB time=2616.3 bitrate= 448.0kbits/s
 size= 143360kB time=2621.4 bitrate= 448.0kbits/s
 size= 143598kB time=2625.8 bitrate= 448.0kbits/s
 size= 143866kB time=2630.7 bitrate= 448.0kbits/s
 size= 144120kB time=2635.3 bitrate= 448.0kbits/s
 size= 144398kB time=2640.4 bitrate= 448.0kbits/s
 size= 144636kB time=2644.8 bitrate= 448.0kbits/s
 size= 144907kB time=2649.7 bitrate= 448.0kbits/s
 size= 145136kB time=2653.9 bitrate= 448.0kbits/s
 size= 145414kB time=2659.0 bitrate= 448.0kbits/s
 size= 145658kB time=2663.5 bitrate= 448.0kbits/s
 size= 145861kB time=2667.2 bitrate= 448.0kbits/s
 size= 146136kB time=2672.2 bitrate= 448.0kbits/s
 size= 146384kB time=2676.7 bitrate= 448.0kbits/s
 size= 146671kB time=2682.0 bitrate= 448.0kbits/s
 size= 146900kB time=2686.2 bitrate= 448.0kbits/s
 size= 147191kB time=2691.5 bitrate= 448.0kbits/s
 size= 147424kB time=2695.7 bitrate= 448.0kbits/s
 size= 147696kB time=2700.7 bitrate= 448.0kbits/s
 size= 147915kB time=2704.7 bitrate= 448.0kbits/s
 size= 148176kB time=2709.5 bitrate= 448.0kbits/s
 size= 148400kB time=2713.6 bitrate= 448.0kbits/s
 size= 148662kB time=2718.4 bitrate= 448.0kbits/s
 size= 148869kB time=2722.2 bitrate= 448.0kbits/s
 size= 149146kB time=2727.2 bitrate= 448.0kbits/s
 size= 149375kB time=2731.4 bitrate= 448.0kbits/s
 size= 149637kB time=2736.2 bitrate= 448.0kbits/s
 size= 149861kB time=2740.3 bitrate= 448.0kbits/s
 size= 150118kB time=2745.0 bitrate= 448.0kbits/s
 size= 150342kB time=2749.1 bitrate= 448.0kbits/s
 size= 150608kB time=2754.0 bitrate= 448.0kbits/s
 size= 150826kB time=2758.0 bitrate= 448.0kbits/s
 size= 151100kB time=2763.0 bitrate= 448.0kbits/s
 size= 151330kB time=2767.2 bitrate= 448.0kbits/s
 size= 151604kB time=2772.2 bitrate= 448.0kbits/s
 size= 151834kB time=2776.4 bitrate= 448.0kbits/s
 size= 152124kB time=2781.7 bitrate= 448.0kbits/s
 size= 152367kB time=2786.1 bitrate= 448.0kbits/s
 size= 152642kB time=2791.2 bitrate= 448.0kbits/s
 size= 152876kB time=2795.5 bitrate= 448.0kbits/s
 size= 153144kB time=2800.4 bitrate= 448.0kbits/s
 size= 153309kB time=2803.4 bitrate= 448.0kbits/s
 size= 153571kB time=2808.2 bitrate= 448.0kbits/s
 size= 153794kB time=2812.2 bitrate= 448.0kbits/s
 size= 154054kB time=2817.0 bitrate= 448.0kbits/s
 size= 154273kB time=2821.0 bitrate= 448.0kbits/s
 size= 154520kB time=2825.5 bitrate= 448.0kbits/s
 size= 154749kB time=2829.7 bitrate= 448.0kbits/s
 size= 155034kB time=2834.9 bitrate= 448.0kbits/s
 size= 155269kB time=2839.2 bitrate= 448.0kbits/s
 size= 155540kB time=2844.2 bitrate= 448.0kbits/s
 size= 155760kB time=2848.2 bitrate= 448.0kbits/s
 size= 156042kB time=2853.3 bitrate= 448.0kbits/s
 size= 156264kB time=2857.4 bitrate= 448.0kbits/s
 size= 156541kB time=2862.5 bitrate= 448.0kbits/s
 size= 156754kB time=2866.4 bitrate= 448.0kbits/s
 size= 157022kB time=2871.3 bitrate= 448.0kbits/s
 size= 157229kB time=2875.0 bitrate= 448.0kbits/s
 size= 157493kB time=2879.9 bitrate= 448.0kbits/s
 size= 157726kB time=2884.1 bitrate= 448.0kbits/s
 size= 157986kB time=2888.9 bitrate= 448.0kbits/s
 size= 158218kB time=2893.1 bitrate= 448.0kbits/s
 size= 158492kB time=2898.1 bitrate= 448.0kbits/s
 size= 158718kB time=2902.3 bitrate= 448.0kbits/s
 size= 158998kB time=2907.4 bitrate= 448.0kbits/s
 size= 159220kB time=2911.5 bitrate= 448.0kbits/s
 size= 159483kB time=2916.3 bitrate= 448.0kbits/s
 size= 159710kB time=2920.4 bitrate= 448.0kbits/s
 size= 159980kB time=2925.3 bitrate= 448.0kbits/s
 size= 160206kB time=2929.5 bitrate= 448.0kbits/s
 size= 160475kB time=2934.4 bitrate= 448.0kbits/s
 size= 160638kB time=2937.4 bitrate= 448.0kbits/s
 size= 160893kB time=2942.0 bitrate= 448.0kbits/s
 size= 161158kB time=2946.9 bitrate= 448.0kbits/s
 size= 161385kB time=2951.0 bitrate= 448.0kbits/s
 size= 161642kB time=2955.7 bitrate= 448.0kbits/s
 size= 161877kB time=2960.0 bitrate= 448.0kbits/s
 size= 162153kB time=2965.1 bitrate= 448.0kbits/s
 size= 162376kB time=2969.2 bitrate= 448.0kbits/s
 size= 162652kB time=2974.2 bitrate= 448.0kbits/s
 size= 162894kB time=2978.6 bitrate= 448.0kbits/s
 size= 163175kB time=2983.8 bitrate= 448.0kbits/s
 size= 163424kB time=2988.3 bitrate= 448.0kbits/s
 size= 163702kB time=2993.4 bitrate= 448.0kbits/s
 size= 163936kB time=2997.7 bitrate= 448.0kbits/s
 size= 164229kB time=3003.0 bitrate= 448.0kbits/s
 size= 164446kB time=3007.0 bitrate= 448.0kbits/s
 size= 164734kB time=3012.3 bitrate= 448.0kbits/s
 size= 164983kB time=3016.8 bitrate= 448.0kbits/s
 size= 165254kB time=3021.8 bitrate= 448.0kbits/s
 size= 165424kB time=3024.9 bitrate= 448.0kbits/s
 size= 165681kB time=3029.6 bitrate= 448.0kbits/s
 size= 165930kB time=3034.1 bitrate= 448.0kbits/s
 size= 166196kB time=3039.0 bitrate= 448.0kbits/s
 size= 166346kB time=3041.8 bitrate= 448.0kbits/s
 size= 166514kB time=3044.8 bitrate= 448.0kbits/s
 size= 166666kB time=3047.6 bitrate= 448.0kbits/s
 size= 166957kB time=3052.9 bitrate= 448.0kbits/s
 size= 167198kB time=3057.3 bitrate= 448.0kbits/s
 size= 167487kB time=3062.6 bitrate= 448.0kbits/s
 size= 167688kB time=3066.3 bitrate= 448.0kbits/s
 size= 167972kB time=3071.5 bitrate= 448.0kbits/s
 size= 168201kB time=3075.7 bitrate= 448.0kbits/s
 size= 168486kB time=3080.9 bitrate= 448.0kbits/s
 size= 168726kB time=3085.3 bitrate= 448.0kbits/s
 size= 169010kB time=3090.5 bitrate= 448.0kbits/s
 size= 169258kB time=3095.0 bitrate= 448.0kbits/s
 size= 169542kB time=3100.2 bitrate= 448.0kbits/s
 size= 169790kB time=3104.7 bitrate= 448.0kbits/s
 size= 170070kB time=3109.9 bitrate= 448.0kbits/s
 size= 170291kB time=3113.9 bitrate= 448.0kbits/s
 size= 170567kB time=3118.9 bitrate= 448.0kbits/s
 size= 170802kB time=3123.2 bitrate= 448.0kbits/s
 size= 171073kB time=3128.2 bitrate= 448.0kbits/s
 size= 171280kB time=3132.0 bitrate= 448.0kbits/s
 size= 171551kB time=3136.9 bitrate= 448.0kbits/s
 size= 171778kB time=3141.1 bitrate= 448.0kbits/s
 size= 172039kB time=3145.9 bitrate= 448.0kbits/s
 size= 172268kB time=3150.0 bitrate= 448.0kbits/s
 size= 172538kB time=3155.0 bitrate= 448.0kbits/s
 size= 172778kB time=3159.4 bitrate= 448.0kbits/s
 size= 173047kB time=3164.3 bitrate= 448.0kbits/s
 size= 173292kB time=3168.8 bitrate= 448.0kbits/s
 size= 173565kB time=3173.8 bitrate= 448.0kbits/s
 size= 173794kB time=3178.0 bitrate= 448.0kbits/s
 size= 174085kB time=3183.3 bitrate= 448.0kbits/s
 size= 174321kB time=3187.6 bitrate= 448.0kbits/s
 size= 174601kB time=3192.7 bitrate= 448.0kbits/s
 size= 174836kB time=3197.0 bitrate= 448.0kbits/s
 size= 175107kB time=3202.0 bitrate= 448.0kbits/s
 size= 175350kB time=3206.4 bitrate= 448.0kbits/s
 size= 175632kB time=3211.6 bitrate= 448.0kbits/s
 size= 175877kB time=3216.0 bitrate= 448.0kbits/s
 size= 176152kB time=3221.1 bitrate= 448.0kbits/s
 size= 176391kB time=3225.4 bitrate= 448.0kbits/s
 size= 176682kB time=3230.8 bitrate= 448.0kbits/s
 size= 176925kB time=3235.2 bitrate= 448.0kbits/s
 size= 177216kB time=3240.5 bitrate= 448.0kbits/s
 size= 177468kB time=3245.1 bitrate= 448.0kbits/s
 size= 177754kB time=3250.4 bitrate= 448.0kbits/s
 size= 178001kB time=3254.9 bitrate= 448.0kbits/s
 size= 178294kB time=3260.2 bitrate= 448.0kbits/s
 size= 178532kB time=3264.6 bitrate= 448.0kbits/s
 size= 178824kB time=3269.9 bitrate= 448.0kbits/s
 size= 179044kB time=3274.0 bitrate= 448.0kbits/s
 size= 179310kB time=3278.8 bitrate= 448.0kbits/s
 size= 179552kB time=3283.2 bitrate= 448.0kbits/s
 size= 179832kB time=3288.4 bitrate= 448.0kbits/s
 size= 180061kB time=3292.5 bitrate= 448.0kbits/s
 size= 180301kB time=3296.9 bitrate= 448.0kbits/s
 size= 180563kB time=3301.7 bitrate= 448.0kbits/s
 size= 180805kB time=3306.1 bitrate= 448.0kbits/s
 size= 181088kB time=3311.3 bitrate= 448.0kbits/s
 size= 181328kB time=3315.7 bitrate= 448.0kbits/s
 size= 181598kB time=3320.6 bitrate= 448.0kbits/s
 size= 181832kB time=3324.9 bitrate= 448.0kbits/s
 size= 182114kB time=3330.1 bitrate= 448.0kbits/s
 size= 182331kB time=3334.0 bitrate= 448.0kbits/s
 size= 182607kB time=3339.1 bitrate= 448.0kbits/s
 size= 182824kB time=3343.1 bitrate= 448.0kbits/s
 size= 183013kB time=3346.5 bitrate= 448.0kbits/s
 size= 183253kB time=3350.9 bitrate= 448.0kbits/s
 size= 183517kB time=3355.7 bitrate= 448.0kbits/s
 size= 183736kB time=3359.7 bitrate= 448.0kbits/s
 size= 184000kB time=3364.6 bitrate= 448.0kbits/s
 size= 184217kB time=3368.5 bitrate= 448.0kbits/s
 size= 184482kB time=3373.4 bitrate= 448.0kbits/s
 size= 184706kB time=3377.5 bitrate= 448.0kbits/s
 size= 184966kB time=3382.2 bitrate= 448.0kbits/s
 size= 185188kB time=3386.3 bitrate= 448.0kbits/s
 size= 185442kB time=3390.9 bitrate= 448.0kbits/s
 size= 185666kB time=3395.0 bitrate= 448.0kbits/s
 size= 185930kB time=3399.9 bitrate= 448.0kbits/s
 size= 186135kB time=3403.6 bitrate= 448.0kbits/s
 size= 186396kB time=3408.4 bitrate= 448.0kbits/s
 size= 186625kB time=3412.6 bitrate= 448.0kbits/s
 size= 186886kB time=3417.3 bitrate= 448.0kbits/s
 size= 187128kB time=3421.8 bitrate= 448.0kbits/s
 size= 187394kB time=3426.6 bitrate= 448.0kbits/s
 size= 187618kB time=3430.7 bitrate= 448.0kbits/s
 size= 187871kB time=3435.4 bitrate= 448.0kbits/s
 size= 188092kB time=3439.4 bitrate= 448.0kbits/s
 size= 188363kB time=3444.4 bitrate= 448.0kbits/s
 size= 188594kB time=3448.6 bitrate= 448.0kbits/s
 size= 188856kB time=3453.4 bitrate= 448.0kbits/s
 size= 189072kB time=3457.3 bitrate= 448.0kbits/s
 size= 189332kB time=3462.1 bitrate= 448.0kbits/s
 size= 189556kB time=3466.2 bitrate= 448.0kbits/s
 size= 189819kB time=3471.0 bitrate= 448.0kbits/s
 size= 190031kB time=3474.8 bitrate= 448.0kbits/s
 size= 190290kB time=3479.6 bitrate= 448.0kbits/s
 size= 190512kB time=3483.6 bitrate= 448.0kbits/s
 size= 190776kB time=3488.5 bitrate= 448.0kbits/s
 size= 191000kB time=3492.6 bitrate= 448.0kbits/s
 size= 191245kB time=3497.1 bitrate= 448.0kbits/s
 size= 191473kB time=3501.2 bitrate= 448.0kbits/s
 size= 191726kB time=3505.9 bitrate= 448.0kbits/s
 size= 191947kB time=3509.9 bitrate= 448.0kbits/s
 size= 192202kB time=3514.6 bitrate= 448.0kbits/s
 size= 192428kB time=3518.7 bitrate= 448.0kbits/s
 size= 192692kB time=3523.5 bitrate= 448.0kbits/s
 size= 192911kB time=3527.5 bitrate= 448.0kbits/s
 size= 193162kB time=3532.1 bitrate= 448.0kbits/s
 size= 193363kB time=3535.8 bitrate= 448.0kbits/s
 size= 193615kB time=3540.4 bitrate= 448.0kbits/s
 size= 193834kB time=3544.4 bitrate= 448.0kbits/s
 size= 194098kB time=3549.2 bitrate= 448.0kbits/s
 size= 194327kB time=3553.4 bitrate= 448.0kbits/s
 size= 194588kB time=3558.2 bitrate= 448.0kbits/s
 size= 194758kB time=3561.3 bitrate= 448.0kbits/s
 size= 195027kB time=3566.2 bitrate= 448.0kbits/s
 size= 195267kB time=3570.6 bitrate= 448.0kbits/s
 size= 195540kB time=3575.6 bitrate= 448.0kbits/s
 size= 195739kB time=3579.2 bitrate= 448.0kbits/s
 size= 195993kB time=3583.9 bitrate= 448.0kbits/s
 size= 196208kB time=3587.8 bitrate= 448.0kbits/s
 size= 196472kB time=3592.6 bitrate= 448.0kbits/s
 size= 196728kB time=3597.3 bitrate= 448.0kbits/s
 size= 197040kB time=3603.0 bitrate= 448.0kbits/s
 size= 197241kB time=3606.7 bitrate= 448.0kbits/s
 size= 197516kB time=3611.7 bitrate= 448.0kbits/s
 size= 197782kB time=3616.6 bitrate= 448.0kbits/s
 size= 198040kB time=3621.3 bitrate= 448.0kbits/s
 size= 198322kB time=3626.5 bitrate= 448.0kbits/s
 size= 198564kB time=3630.9 bitrate= 448.0kbits/s
 size= 198846kB time=3636.0 bitrate= 448.0kbits/s
 size= 199082kB time=3640.4 bitrate= 448.0kbits/s
 size= 199355kB time=3645.3 bitrate= 448.0kbits/s
 size= 199586kB time=3649.6 bitrate= 448.0kbits/s
 size= 199871kB time=3654.8 bitrate= 448.0kbits/s
 size= 200158kB time=3660.0 bitrate= 448.0kbits/s
 size= 200475kB time=3665.8 bitrate= 448.0kbits/s
 size= 200739kB time=3670.7 bitrate= 448.0kbits/s
 size= 201026kB time=3675.9 bitrate= 448.0kbits/s
 size= 201264kB time=3680.3 bitrate= 448.0kbits/s
 size= 201542kB time=3685.3 bitrate= 448.0kbits/s
 size= 201764kB time=3689.4 bitrate= 448.0kbits/s
 size= 202032kB time=3694.3 bitrate= 448.0kbits/s
 size= 202262kB time=3698.5 bitrate= 448.0kbits/s
 size= 202531kB time=3703.4 bitrate= 448.0kbits/s
 size= 202772kB time=3707.8 bitrate= 448.0kbits/s
 size= 203040kB time=3712.7 bitrate= 448.0kbits/s
 size= 203285kB time=3717.2 bitrate= 448.0kbits/s
 size= 203556kB time=3722.2 bitrate= 448.0kbits/s
 size= 203772kB time=3726.1 bitrate= 448.0kbits/s
 size= 204032kB time=3730.9 bitrate= 448.0kbits/s
 size= 204264kB time=3735.1 bitrate= 448.0kbits/s
 size= 204530kB time=3740.0 bitrate= 448.0kbits/s
 size= 204757kB time=3744.1 bitrate= 448.0kbits/s
 size= 205023kB time=3749.0 bitrate= 448.0kbits/s
 size= 205264kB time=3753.4 bitrate= 448.0kbits/s
 size= 205525kB time=3758.2 bitrate= 448.0kbits/s
 size= 205742kB time=3762.1 bitrate= 448.0kbits/s
 size= 206014kB time=3767.1 bitrate= 448.0kbits/s
 size= 206238kB time=3771.2 bitrate= 448.0kbits/s
 size= 206313kB time=3772.6 bitrate= 448.0kbits/s
 video:0kB audio:20631
	I don't see errors, it seems to just stop before authoring.
 Mine says:Originally Posted by macsnooder
 INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
 FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
 built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
 So it seems you're using an older version of ffmpegX (0.0.9t perhaps?). Please consider upgrading to the current version, ffmpegX 0.0.9x r2 at this time.
 ffmpegX 0.0.9t did have a bug in the author tool, which might be a reason why it didn't continue to create the VIDEO_TS folder.
  batch dvd ripping - output folder to input folder?By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23
  Wgat would be the proper folder structure to add movie cover to a folderBy VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09
  WPDNSE folder inside your system Temp folder????By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 09:35
  Problem-video folder not availableBy sgraves425 in forum Blu-ray RippingReplies: 1Last Post: 17th Jun 2010, 19:35
  Newbie converting video t_s to .movBy coast2coast in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 13:01
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
