Is there a way to rip a public-domain conventional dvd which has multiple audio tracks and subtitle sets and, of course, chapters and a menu, into a Divx 6 file which preserves all the audio tracks, subtitle sets as well as chapter points and menu?
I currently use CloneDVD2 to make backups of dvds. It makes it child's play to select just the content from the original dvd that I want and ignore the rest. However, it only outputs (1) burned conventional dvd, (2) iso image of the original or (3) copies desired VOBs to the hard drive. I also use, occasionally, CloneDVDMobile, which will easily create divx files, but only divx 5, with no support for menus, chapters, subtitles or multiple audio tracks.
What I want is something which is as easy to use as CloneDVD2, but which will output a Divx 6 file with menus, chapters, subtitles and audio tracks. I seek this, because I'm ready to create a video fileserver in my home with full-featured backup copies of every film I own, but I don't want to lose features or resolution, but I'd rather store each file in a about 1gb +/-, instead of the 5-8gb that most originals.
Does such a tool exist? At any price?
DivX Author ( http://www.divx.com/products/sw/detail.php?p=367 ) should allow you to convert your DVD to Divx 6 with all the audio tracks and subtitles. You'll have to create your own menus and probably the chapter points too. There are no tools that you allow to input a DVD and copy it, menus and all, into Divx format. DivX Author is as close as you can get to what you want to do.
URGENT: Need to output to ASP DivX w/ Multiple Subs, Audio Tracks, Chapters
By Jeet in forum Authoring (DVD)Replies: 0Last Post: 7th Oct 2010, 17:14 -
DVD to MPEG2, extract mult audio tracks, subtitles for replay in WD TV Live
By Jacoman in forum DVD RippingReplies: 5Last Post: 16th Mar 2010, 10:40 -
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 03:09 -
It is possible to add chapters in divx dvd ? subtitles ?
By carl25 in forum Authoring (DVD)Replies: 7Last Post: 3rd Jul 2009, 00:06 -
authoring DVD with 2 audio tracks and soft subtitles
By Agent1266 in forum ffmpegX general discussionReplies: 6Last Post: 2nd Oct 2008, 16:34
