the AVI file doesn't have black borders. i want the DVD format to not have black borders also. does anyone know how to do that?
I've only "fooled around" with AVIDemux but most MPEG-4 AVI files (DivX and XviD) use a 1:1 pixel aspect ratio. So you would use that as your source assuming that is the kind of AVI file you are talking about.
As for the destination ... if the source is widescreen then use 16:9 for the destination. If the source is 1.33:1 Full Screen then pick 4:3 as the destination.
You can always use GSpot to determine the properties of the source AVI file.
Load your AVI into GSpot and post a screen shot of it.
Then I'll tell you.
And if your aspect ratio isn't exactly 4:3 or 16:9 then you will have to add black border to bring your resolution up to DVD spec, or crop and resize. Adding borders is the better option as it doesn't degrade the image to the same degree.
Read my blog here.
Trying to convert AVI to MP4 (for iPad) -- Avidemux won't install
By monkeypack in forum Video ConversionReplies: 4Last Post: 28th Nov 2011, 08:18 -
Avidemux - WMV file convert to MP4 - Audio stream garbled
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2011, 14:52 -
Cant convert Pal .AVI to NTSC DVD in Avidemux
By Hittz in forum Video ConversionReplies: 6Last Post: 5th Nov 2009, 07:43 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 10:10 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 19:21
