I installed then removed Norton System Utilities and DVD2AVI no longer works the same as before.
Specifically I get a pop up window after starting the SAVE AVI command. The window ask for the compression method. The drop down menus have NO COMPRESSION, FULL FRAME, DIVX 4.12, etc.
I never had this pop up menu before. What is this? How do I get rid of it? If I choose Full Frame or NO compression, it stops and a 0kb file is created? I can preview the file. I can also choose one of the other items such as DIVX, and it will save the file. I'm looking to frame serve for input into TMPGENC.
Any thoughts?
problem with MPC/HC after spyware removal
By spiritgumm in forum Software PlayingReplies: 4Last Post: 6th Mar 2011, 10:55 -
Command line conversion / joining utilities
By jxfish2 in forum Video ConversionReplies: 1Last Post: 20th Aug 2010, 17:24 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 10:47 -
Another install problem
By AlecD in forum ffmpegX general discussionReplies: 3Last Post: 3rd Jun 2008, 14:45 -
Windows utilities to strip Javascript?
By Ai Haibara in forum ComputerReplies: 12Last Post: 22nd Sep 2007, 20:37
