Hi guys. Just wondering if you could help. I have connected my laptop up to my LCD TV via a VGA cable. It works fine apart from a blue square in the top left hand corner on the TV that I cant get rid of? Any ideas?
Thanks,
Sounds like your TV has PIP (Picture In Picture) displays or it's keeping a spot for channel display. You might want to check your TV manual. How big is the blue square?
And welcome to our forums.
Great!! Thanks for the help! It was a simple solution! The PIP button on the remote did the trick! Thanks for helping me.
problem with vga y splitter
By armedfitz in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2010, 06:30 -
problem getting vga to work with hdtv
By GetYourShineBox in forum Newbie / General discussionsReplies: 16Last Post: 26th Feb 2010, 16:42 -
PC VGA to VGA on LG 42" Plasma
By Squirralien in forum Media Center PC / MediaCentersReplies: 3Last Post: 8th Nov 2008, 20:43 -
laptop with only VGA to VGA-less HDTV
By liiam in forum DVB / IPTVReplies: 0Last Post: 16th Oct 2008, 14:16 -
VGA to TV Problem!
By DonEve in forum ComputerReplies: 1Last Post: 20th Jan 2008, 10:15
