Hello,
I'm a registered user of SVCD2DVD and I've got problems since I updated to the newest 2.5 version.
I'd like to make a Music DVD with MPEG2 files (single musicclips). I had done this many times before without problems but now... Let me explain: If I insert the Assets e.g. 1 Musicvideo (as MPEG2 file: file size is 65MB) in the VTS Layout the size for this 1 file is shown as 288MB in the newest SVCD2DVD version!!! In former Versions the size of this File was shown as ~118MB (Also other files are 4-times bigger!!!). When I click create your DVD in the newest version now the AVI2MPEG engine starts?!? In former versions this don't happen...only processing file and finish. This is bad for me because I don't have a former version of the 2.5 Engine anymore only a 2.1 Demo version. In the 2.1 it works fine with the same file. So anybody could tell me where I can find former 2.5 versions to test (Because I know that there was a earlier 2.5 Version that works fine without this problems.)
Maybe anybody can e-mail me a former 2.5 Version to Bluechip16@gmx.de
Many Thanks!!!!!
Post your log from a run that displays this behavior.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.3600.0
Executable: C:\Programme\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2,57 MB
Executable size in bytes: 2703443
Executable CreationTime: 09.12.2007 16:41:26
Executable LastWriteTime: 20.01.2008 10:58:03
Executable LastAccessTime: 21.01.2008 08:55:40
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1031
CodeSet: 1252
CountryCode: 49
Local: 0407
Total Physical Memory: 0,99 GB
Free Physical Memory: 545 MB
Total Virtual Memory: 1,99 GB
Free Virtual Memory: 1,95 GB
***************************** Computer *****************************
Computer Manufacturer Name: System manufacturer
Computer Model: System Product Name
System Type: X86-based PC
Computer Name: STEVE
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: STEVE\Bluechip82
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) 64 Processor 3000+
Description: x86 Family 15 Model 47 Stepping 0
CPU Speed: 1,89GHz
CPU FSB: 210MHz
L2 Cache Size: 512 Byte
***************************** Time Zone ****************************
Time Zone:
****************************** VIDEO *******************************
Name: NVIDIA GeForce 6600
Processor: GeForce 6600
Mode: 1280 x 1024 x 4294967296 Farben
Video Ram: 256 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 5,02 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 5,29 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 11,7 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 488 MB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 32,3 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="21.01.2008 10:08:41" Filename="NONE">
<AssetSet>
<Asset ID="db53c472-02ca-4a12-9e21-00edc12bea0b" Path="E:\" Filename="File1.mpg" />
</AssetSet>
<DVDStructure>
<TitleSet Name="New Movie" PostCmd="" MenuButtonType="0">
<MenuButton X1="0" Y1="0" X2="226" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">New Movie</MenuButton>
<Title Name="File1.mpg" AssetID="db53c472-02ca-4a12-9e21-00edc12bea0b" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Programme\BadgerIT\SVCD2DV D v2.5\default.jpg" AudioPath="" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="" InitialDVDFolder="" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="skip" Chapters="Every 0 mins (none)" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 65,1 MB
file=E:\\File1.mpg
FormatName=mpeg
Num_Frames=5164
DurationInSecs=206
Duration=00:03:26.5
VideoCodec=mpeg2video
VideoFFSTNum=0
Width=544
Height=576
Standard=PAL
BitRate=2645
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x1c0]
Audio1SampleRate=48000
Audio1Codec=mp2
Audio1BitRate=192
Audio1Channels=2
AVI2MPG: 9000kbs Full-D1
Pass 1/1: Processing File1.mpg
10:08:42: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
10:08:42: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
10:08:42: libavutil version: 49.1.0
10:08:42: libavcodec version: 51.27.0
10:08:42: libavformat version: 51.12.1
10:08:42: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
10:08:42: Input #0, mpeg, from 'E:\File1.mpg':
10:08:42: Duration: 00:03:26.5, start: 2078.104656, bitrate: 2645 kb/s
10:08:42: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 544x576, 2400 kb/s, 25.00 fps(r)
10:08:42: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 192 kb/s
10:08:42: Output #0, dvd, to 'E:\File1_S2D.mpg':
10:08:42: Stream #0.0: Video: mpeg2video, yuv420p, 720x576, q=1-31, 9000 kb/s, 25.00 fps(c)
10:08:42: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
10:08:42: Stream mapping:
10:08:42: Stream #0.0 -> #0.0
10:08:42: Stream #0.1 -> #0.1
10:08:42: Press [q] to stop encoding
10:11:36: [mpeg2video @ 00822700]ac-tex damaged at 13 1
10:11:36: [mpeg2video @ 00822700]Warning MVs not available
10:11:36: [mpeg2video @ 00822700]concealing 1190 DC, 1190 AC, 1190 MV errors
10:11:36: video:161838kB audio:11317kB global headers:0kB muxing overhead 1.963946%
10:11:36: AVI2MPG: done.
10:11:36: Done: Processing assets for DVD creation
Authoring DVD Folders
10:11:36: Creating TitleSet # 1
10:11:36: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
10:11:36: -->: DVDFolders creating VTS
10:11:36: -->: VTS 01
10:11:36:
DVD Folders: Processing E:\File1_S2D.mpg...
10:11:39:
10:11:39:
10:11:39: Finalising DVD...
10:11:39: SVCD2DVD: DVDfolders
10:11:39: -->: DVDFolders creating table of contents
10:11:39: scanning E:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
10:11:39: Finalising DVD...Done
10:11:39: Done: Authoring DVD Folders -
And here is the log file with the same file but old SVCD2DVD Version 2.1. Here everything works fine for me.
Name: SVCD2DVD 2.1 DEMO
Title: 2.1 DEMO
Version: 2.1.2308.0
Executable: C:\Programme\SVCD2DVD21\SVCD2DVD.exe
Executable size: 2,50 MB
Executable size in bytes: 2621440
Executable CreationTime: 28.04.2006 09:59:52
Executable LastWriteTime: 28.04.2006 09:59:52
Executable LastAccessTime: 21.01.2008 09:13:40
Version : 5.1.2600
OSLanguage: 1031
CodeSet: 1252
CountryCode: 49
Local: 0407
Free Physical Memory: 542 MB
CPU Speed: 1,89GHz
CPU FSB: 210MHz
Time Zone:
Video Ram: 256 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 5,02 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 5,29 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 11,7 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 488 MB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 32,3 GB
<SVCD2DVD DateTime="21.01.2008 10:14:38" Filename="NONE"><AssetSet><Asset ID="d28233b9-431e-4915-a908-4675668d5282" Path="E:\" Filename="File1.mpg" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="File1.mpg" AssetID="d28233b9-431e-4915-a908-4675668d5282" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Programme\SVCD2DVD21\defau lt.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="skip" Chapters="Every 0 mins (none)" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" DVDDrive="HL-DT-ST DVD-RAM GSA-H50L" NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
File Size: 65,1 MB
file=E:\File1.mpg
FormatName=mpeg
Num_Frames=5164
DurationInSecs=206
Duration=00:03:26.5
Width=544
Height=576
Standard=PAL
BitRate=2645
AudioStreamCount=1
Audio1Codec=mp2
Audio1BitRate=192
Audio1Channels=2
10:14:38: Done: Processing assets for DVD creation
10:14:38: Creating TitleSet # 1
10:14:38: SVCD2DVD: DVDfolders
10:14:38: -->: DVDFolders creating VTS
10:14:38: -->: VTS 01
10:14:38:
10:14:41:
10:14:41:
10:14:44: Finalising DVD...
10:14:44: SVCD2DVD: DVDfolders
10:14:44: -->: DVDFolders creating table of contents
10:14:44: scanning E:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
10:14:44: Finalising DVD...Done
10:14:44: Done: Authoring DVD Folders -
It is because the source files do not have DVD dimensions:
Width=544
Height=576
Otherwise drop me an email and i will send you a build which doesn't reencode the mpegs to compliant DVD resolutions.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
emails sent
Video capture, editing & redndering in 1680x1050 - BIG PROBLEMS
By casparticus in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2011, 16:57 -
what is the latest version for quicktime ???
By khalid81 in forum Software PlayingReplies: 2Last Post: 10th Jun 2009, 17:40 -
Latest Version of VLC
By Wanderlustus in forum Software PlayingReplies: 6Last Post: 20th Feb 2009, 12:47 -
Can't open older TMPGEnc DVD Author files in latest version
By steelborn in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2008, 13:55 -
Any problems with Xvid latest version and AVIReComp?
By Relayerman in forum Video ConversionReplies: 1Last Post: 30th Jan 2008, 10:00
