Hi
Recently i have tried to convert a video file, but i have not been able to do it.
So what i would like to do is capture/record this video file by playing it using VLC Media player
and use a Capturing/recording software to record it.
I have tried some screen recorder software but they did not work.
Grateful for any help
You can convert with vlc media player also. Choose file->open file and click on stream/save and select file and a format like mpeg1,mpeg2 and choose codecs. Then you can reconvert it again if want some other format that vlc doesn't support.
Hi Baldrick
I have tried this before, but i get Unable to open 'C:\Documents and Settings
I got the same when i tried to convert! The file is supposed to be broken/corrupt.
Yet, i can play the video file, and it plays perfect.
I need some video recording device.
Thanks -
Depends on the file type/format. If it is a DRM encrypted file, for instance, it will play, but it can't be converted. What is the source file type? Where is it from etc, etc?
It's also possible the file is "broken/corrupt". VLC can often play files that are corrupt or incomplete, but they can't be edited/converted/fixed.Google is your Friend
Streaming VOB Video Files from Windows 7 Ultimate Media Player 12
By ziggybuds in forum Video Streaming DownloadingReplies: 2Last Post: 6th Sep 2010, 08:44 -
What Media player is best playing MTS. video files
By marionr26 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 33Last Post: 14th Aug 2010, 18:30 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Video Problem with Divx/Xvid files on Media Player
By Vid-Kid in forum Media Center PC / MediaCentersReplies: 2Last Post: 16th Dec 2007, 22:09 -
how do I flip an AVI video in windows media player or media player classi
By mdavenport in forum Newbie / General discussionsReplies: 2Last Post: 5th Jul 2007, 23:18
