Hello
I exported my movie in adobe premiere pro 2.0 and i used the uncompressed avi setting in order to achieve the best quality picture. The exported verson of my 14min movie came out to be 19.9GB and now I canot put it into nero to make a dvd because it is too large. Is there a program that can compress my video to a custom size or should export again in another setting. If I export again what setting should I use to get the best quality but a lower file size. I would be happy if it was just a few gigs but not 20.
Any help would be great, thanks
Marcos
	start over. everytime you render it, it will lose quality. try again and maybe go straight to dvd spec mpeg-2. which you can then import into an authoring program and not have to encode a second time. --
  Compressing an uncompressed AVI for Adobe Elements 10By Daniel_BMS in forum EditingReplies: 5Last Post: 9th Mar 2012, 20:57
  Can you import from Adobe After Affects to Adobe Premiere Pro?By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43
  Uncompressed From Premiere Pro to Xvid4PSPBy x2x3x2 in forum Video ConversionReplies: 6Last Post: 30th Mar 2011, 05:04
  Trancoding uncompressed avi in Adobe EncoreBy seanadl in forum Authoring (DVD)Replies: 4Last Post: 5th Aug 2008, 16:07
  Cant import AVI files into Adobe Premiere Pro 1.5 (again)By Undead Sega in forum EditingReplies: 1Last Post: 13th Oct 2007, 21:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
