    Sep 2007
    somewhere in videohelp
    hi, i want remove/delete the first play and change it to another vob, how can i do it ?
    Apr 2004
    Miskatonic U
    Click on PGCEdit in this post to go to the tools page for it. There you will find guides on how to use PGCEdit to this. I believe it is now almost a one click process.
    Read my blog here.
    Sep 2007
    i will try it, thank you
  4. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    DVDRemake: (after importing the source for new VOB as a separate project) right click on line in programs list -> replace block. Generally the new source should have the same stream types as determined in the domain where that first play item resides, but there can be a work-around.
    If you want to simply delete it, use 'hide block' command or 'add post to pre commands' in DVD tree to bypass it without removal.
    Sep 2007
    thank you
