From the how to section it said
"Under Video you can select quality, Use High Quality. (if it is DivX, ASF to MPG you can use Low or Normal Quality)."
If I am converting .avi to vcd mpg which qualiy should I use ?
Results 1 to 1 of 1
Capture card quality question
By Hackerpcs in forum Capturing and VCRReplies: 22Last Post: 18th Nov 2010, 17:41 -
I have a question how to get hd quality on a tuner
By sdavis in forum Capturing and VCRReplies: 5Last Post: 16th Dec 2008, 16:52 -
Video Quality Question
By Augie5390 in forum Video ConversionReplies: 24Last Post: 10th Oct 2008, 19:35 -
Question about Quality between I-P-B frame
By Starkian in forum Newbie / General discussionsReplies: 5Last Post: 12th Jul 2008, 02:52 -
DV to dvd quality question
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Nov 2007, 03:12
