I am a bit baffled about this camcorder. I can use it fine and understand all the principles, but I want to get the video off of the camera onto my pc so that I can edit/convert it. The issue is that the files are stored as mpg's which is fine with me. The issue turns out that the sound is NOT inside the mpg. If you just browse the hard drive in the camera from your pc, you see the mpg and if you play it in any player, it plays the movie with no sound. However, if you use the crappy Sony software, it will play with sound. Thats the issue though, I have to use that software and it is not capable of doing what I want. For example, I want to make some video edits, then save it in an avi and a DVD format on my pc hard drives. With the Sony software, you can ONLY send it to a DVD directly, and not to DVD file storage on your pc hard drive. You also cannot convert to over formats. I have done all this many times before when the sound is included in the files, but since the sound is seperate, I do not know how to handle it.
Any ideas?
Results 1 to 1 of 1
DFI LanParty NF4 SLI-DR
AMD 64 x2 4400+ Toledo
thermalright xp-90 w/arctic silver
2GB (4x512) Ocz EL VX DDR500
Asus 7800GTX 256mb PCI-E x16
Hitachi SATAII 2x160GB RAID 0
OCZ 600w GamerXtreme
Audigy 2 ZS Gamer
Plextor PX-740a DL DVDRW
Why does your system have audio/video sync issues?
By Will Hay in forum Capturing and VCRReplies: 65Last Post: 15th Sep 2024, 01:15 -
SONY BRAVIA - 32" LED - Video play back issues from USB port.
By iRecycle in forum DVB / IPTVReplies: 13Last Post: 10th Aug 2013, 02:15 -
Questions for Improving Sony DCR-TRV22 Video Capture Support
By fredberry in forum Capturing and VCRReplies: 3Last Post: 2nd Nov 2008, 14:59 -
Audio Video Sync issues with AVI.net
By siratfus in forum Video ConversionReplies: 3Last Post: 9th Aug 2008, 00:13 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 20:03
