Results 1 to 11 of 11
  1. Newegg has drives from Samsung, Liteon, Pioneer.....Prices aren't dramatically different.
    What model(s) are recommended? Last drive I bought was an IDE based NEC unit which worked out ok.
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Get the SAMSUNG S302B drive from Newegg.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
    Be aware that certain sata controller chipsets on motherboards could render compatibility issues. If your motherboard has INTEL ICH7/8/9 controller chipset you should be fine. NVIDIA SATA controller chipset you'll need to download the latest drivers from their website and if you have VIA SATA controller chipset then the SATA DVD burner will not work correctly. You'll have to buy a SATA PCI CONTROLLER card w/the SILICON IMAGE 3112/3114 chipset. The SATA controller chipset will determine whether or not a SATA DVD Burner will work correctly. RAID will have to be disabled as well in the motherboard bios for the drive to work correctly as well. Don't use the JMICRON chipset as well.
    If this information is too technical for you to understand then just buy a PATA INTERNAL PIONEER 115 drive.
    May 2006
    My $0.02 I go with SATA on Hard drives and IDE on burners - Pioneer only.
  4. Motherboard I'm looking at uses AMD SB600. It supports Raid0, 1 and 10. I assume Raid0 means RAID off.
  5. Pioneer...
    Raid 0 means 2 Sata Drives as one >. got it? double the speed, double capacity and double the failure points.
    Raid 1 is mirroring, 2 drives as 1. this is safe, if 1 drive goes bad...you have the other "mirror" and you can rebuild the raid again.
  6. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    You'll need to find out what SATA controller chipset is on your motherboard. Just make sure RAID is disabled in your motherboard BIOS. What's the brand of your motherboard? ASUS? MSI? GIGABYTE?
    Aug 2006
    I'd second Budz on the Samsung 203 recommendation. I picked one up a couple of weeks ago and have been very happy with it. My ASUS mobo uses the ICH9 controller.
    A couple of reviews:
    http://www.cdfreaks.com/reviews/Samsung-SH-S203B-DVD-Burner-Review
    http://www.cdrlabs.com/reviews/index.php?reviewid=306
  8. Thanks, I ordered the 203N. I don't think I'll ever use lightscribe but this unit ships free so it's cheaper then 203B.
  9. Going Mad TheFamilyMan's Avatar
    Jan 2004
    south SF bay area, CA USA
    Amazing deals on DVD writers nowadays. About a week ago I got the Samsung 202J from newegg for $25 w/free shipping to replace my fading $175 pioneer a06 of 4.5 years. Newegg even threw in the same nero OEM disk that ships with the retail version, which to my suprise is excellent software considering the crapware that you usually get (I cherry-picked the install BTW). All in all, an amazing deal!!! Good luck with your new drive!
    Usually long gone and forgotten
  10. Member wulf109's Avatar
    Jul 2002
    WD 1600AAJS is faster than than normal SATAII drives. Some have compared it's speed to the Rapture series. They have reduced my transcode speeds by 15% compared to normal SATAII drives.
  11. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Ummmm.....this thread is about SATA DVD Burners not hard drives.
