Hello,
I use virtualdub and virtualdubmod for all my encoding. The only probem is when I playback my Video on the problematic Iriver X20, the video ends about half a second short only on the iriver, not on the pc, is there any way I can add blank black frames at the end of the video to fix this problem using virtualdubmod?
Thanks.
Hi-
If you use AviSynth for frameserving into VDubMod, then the BlankClip command can add a series of black frames - as many as you define - to the end of the video:
http://avisynth.org/mediawiki/BlankClip -
You do it by frameserving into VDubMod using an AviSynth script. For specifics as to the kind of a script you'll need, I'd need to know what you're encoding. Are you making AVIs from DVD sources? If so, how are you doing it now? How are you getting the DVD files into VDubMod?
But if you have no interest in learning AviSynth, then maybe someone else will come along with another way to do what you want. -
I currently have an mpeg file that I am encoding into xvid with virtualdub.
Hi-
OK, say you wanted to add half a second of black to the end a PAL 25fps video. Well, 13 frames isn't exactly half a second but you'll get the idea:
LoadPlugin("C:\Path\To\DGDecode.dll")
A=MPEG2Source("C:\Path\To\Video.D2V")
B=BlankClip(A,Length=13)
A+B
Crop(8,0,-8,0)
LanczosResize(512,384)
Adjust for your paths and names. Also adjust for the crop and resize of your AVI. This is just for one I had lying around I was using for testing. This is a script for a soundless AVI. You'll mux in the audio when done encoding the video, or even while encoding by opening it separately in the Streams section of VDubMod or the Audio section of VDub. You can do something similar by using the Loop command to repeat the last frame for as long as you might like.
http://avisynth.org/mediawiki/Loop
A way to insert black in frames' center and vertically push apart video?
By sincostan45 in forum EditingReplies: 5Last Post: 10th Jun 2011, 17:40 -
Are you able to insert blank video into hd h264 without reencoding?
By yoda313 in forum EditingReplies: 2Last Post: 5th Jun 2010, 23:42 -
How to remove giant blank space at end of movie file?
By Quetzecotyl in forum EditingReplies: 2Last Post: 30th Jan 2009, 17:55 -
Avisynth drops blank frames?
By wfael in forum EditingReplies: 3Last Post: 9th Dec 2008, 22:06 -
How to Paste Insert frames from Virtualdub (Snapshot source frame) ?
By Bilskate in forum EditingReplies: 1Last Post: 18th Aug 2008, 15:21
