I have encoded some files and upon testing I noticed that if I encode in PAL the video seems to be bigger
than NTSC encodes... im aware PAL has more lines but it is also 'Wider' (though not out of proportion), it does this on ALL encoding programs as ive tried it... As im encoding HD to SD im now preferring to use PAL (even though the file is 23.97 NTSC) cos the picture being bigger on PAL looks more defined/better (as it has more pixels) on my HDTV than the NTSC version
Is there a program that will tell me the resolution of these VOB files? so i can post em in this thread
				Results 1 to 18 of 18
	GSpot
 /Mats
	yeah i know but as i said before all the apps I use also make them wider so the image is MUCH bigger (still in same ratio) and therefore as Im downcoding HD to SD the playback of the PAL version is MUCH better quality than NTSC on my TV as the PAL has more pixels used than NTSC and therefore looks more defined
	Because it is the same width. what's harder to understand is why your TV shows it wider than the NTSC version. If both are 16:9, they should both play back full screen (on a 16:9 TV)Originally Posted by snadge
 /Mats
	VLC on the comp shows the PAL version to be much wider and taller (just a bigger version of NTSC really, but is VLC showing me the true size? experience tells me it is..... if its WAS the same length then it would look stretched up down as it has more lines but it doesnt
 do you know what i mean?
 VLC playsback in true size....
 and the PAL + NTSC playback in same ratio but PAL is wider aswell as longer but in same ratio (no stretching)
 I wish i could take a screenshot to show you....
 its as if there is more than 720 pixels across in the PAL version during playback in VLC
	No. VLC is shows the video at the height at which the video is encoded (480 NTSC, 576 PAL) and adjusts the width to achieve the proper aspect ratio. Both PAL and NTSC use the same frame width, 720 pixels. A 16:9 DAR source will be displayed at 854x480 (NTSC) or 1024x576 (PAL). So even though the PAL image is displayed much wider it has no more detail on the horizontal axis. It does have 20 percent more detail on the vertical axis (assuming the source had that detail). And it has about 17 percent less temporal resolution (25 fps vs 30 fps, again, depending on the source).Originally Posted by snadge
	thanks Jagabo - thats cleared it up....
 so if my source is 720p HD im best encoding in PAL (SD) as it does have the detail to put into that extra 20% vertical axis...
 MY TV and DVD player handles both formats and PAL is standard for my location, but what would playback best quality on my DVD/TV...?
	About the NTSC vs PAL resolution.
 It isn't strictly true to say that they both have 720 horizontal resolution. Both are analog formats and the concept of pixels is meaningless. However, they are both 4:3 formats (originally). Where they differ is the number of scanlines per frame - 480 for NTSC, 576 for PAL.
 Now, when the signal is digitized, if you want to end up with square pixels, you'd need to sample each horizontal line 640 times for NTSC and 768 times for PAL. (The 640 x 480 is where the VGA size comes from).
 However, for various reasons, DV, DVD and other formats sample at what is known as the D1 rate which is 720 times per scanline. As a result, if you display the digitized image with square pixels, NTSC frames will look somewhat skinnier than they should and PAL frames will look somewhat fatter than they should. The NTSC frame would be shorter, too. A good media player will squeeze the frame into a rectangle with the correct 4:3 ratio (16:9 for widescreen).
 Regarding your question about which format to use - if all your equipment can natively support NTSC, stick with it. Your original format is NTSC. Recoding as PAL will simply scale the image slightly vertically and when you play it back it will be squished into the same size space on the TV as it would be for NTSC. If anything you may lose some detail.
	I understand what you mean about squished into same space but the thing is it doesnt?? when i Playback the NTSC or PAL versions on my 16:9 HDTV through my DVD player they look the same ratio and everything
	....and its not zoomed or anything, everything is fit onto 16:9...no sides or top/bottom missing....
	In terms of resolution, yes.Originally Posted by snadge
 PAL will give you the best resolution. But frame rate issues could cause jerkiness. What is the frame rate of your source?Originally Posted by snadge
 Of course. They are both 16:9 DAR. They are supposed to be scaled to fill a 16:9 display.Originally Posted by snadge
	most are NTSC... but i Encoded (as a test) NTSC to PAL and there was the barely any jerkiness and what there was you coud see on NTSC aswell (the source isnt jerky) 1 frame replaced per second, they were an exact match except for size, now id rather have PAL for the extra resolution, whatever is output my HDTV makes it fit onto screen and id rather have 576 lines fit onto the screen instead of 480 that way the picture quality would be better
	You could also speed up the frame rate to 25 fps and adjust the audio to match. That will give you perfectly smooth playback.Originally Posted by snadge
	Note also to the original poster that speeding up the frame to 25 fps will cause the audio to be about 4% faster. This is noticeable and results in a higher pitched sound. It is possible with certain audio editors to take the audio and drop the pitch back down to counteract this, but that's not easy for newbies to do.Originally Posted by jagabo
	i dont even know how to speed up a movie from 23.97 to 25fps....?
 the playback is good enough for me anyway, you can only notice it in v. fast pans left to right
  Is PAL 576 Higher Resolution Than NTSC 480?By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10
  Changing AVI Properties (Resolution, FPS etc) NTSC>PALBy skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 21:45
  Bigger resoltuion to smaller resolutionBy cyberlion in forum EditingReplies: 16Last Post: 19th Aug 2010, 07:46
  how to convert ntsc to pal without changin the resolution?By Remyisme in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2009, 18:30
  Bigger file with lower resolution after conversion???By unplug in forum EditingReplies: 6Last Post: 20th Aug 2008, 17:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
