Hello,
I play a Chinese movie in AVI format with idx/sub subtitle, it shows 2 identical wording phrases of the subtitle on the screen for every frame it plays in the whole movie. Example:
Here it is
Here it is
I tired to use SubtoSUP to extract the subtile format into sup format, then use DVDSubEdit to play the subtile and it shows the Chinese correctly on the screen, then I use DVDSubEDIT's OCR button to convert the current sub into srt format, but when play it the subtitle is displayed with nonsense characters. I think the problem is the OCR function does not recognize and scan properly into translation.
Can anyone know how to solve this issue or know other method to convert into srt file.?
Thanks in advance.
I think you need to convert idx/sub to srt sub.Use notpad or wordpad to delete the language you don't want to display.
Yes, you remember correctly. Both DirectVobSub and the subtitle engine of whatever player you're using are displaying the subs. Just turn off the subs of your player.
I want to see the subtitle on playback for the whole movie. If I playback on PC with sub subtitle, it displayed fine. I am aware that sub can not be displayed when play on DVD player. As a result, I was able to connvert the sub to srt, but the srt file is contained all non recognizable characters, which also displays the same result on either PC or DVD player.Originally Posted by redwudz
To confirm this, I can see the sub correctly with Chinese subtitle on PC, but not on DVD player.
There must be some sort of converter available to do the conversion.
Subtitles appear in the menu but no on the screen
By dexter30 in forum SubtitleReplies: 4Last Post: 25th Feb 2010, 22:35 -
Same dvds but not all play identical
By aliefjoker in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2008, 11:44 -
Why do i get 2 identical subtitles running over each other?????
By Arwen-Katie89 in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2007, 18:41 -
Problems with Subtitles Position on screen
By impulse_16 in forum SubtitleReplies: 11Last Post: 27th Oct 2007, 11:06 -
Why won't identical hard drive work in another identical PC?
By rijir2001 in forum ComputerReplies: 8Last Post: 25th Jun 2007, 10:12
