I am new to video editing. I just bought a Sony HDR-SR8 which records in both standard and AVCHD. I've been reading the posts about AVCHD and am thinking that I bought the wrong camcorder. But since I have it, and since my computer is 5 years old, I need to either build or buy a computer that will handle AVCHD. Can someone please tell me what components should be in the computer? I'd like to read and write Blu-ray as well. Any help would be appreciated.
build what you can afford. fast cpu/ram/video/drives. or opt for something like dell builds for gamers. the xps series. offers blu-ray writer as an option and all the speed/drives you can pay for
A computer with about a 3Ghz processor and 1GB of DDR2 memory would do it, along with the XP OS. A quad core CPU would be a good upgrade, or at least a dual core.
Two or more hard drives. The boot drive doesn't need to be that big, even 80GB is enough. For the other drive(s), bigger is better. 300 - 500GB. One or two extra drives besides the boot.
If you are just editing or encoding, video cards don't really matter. A good name brand power supply and a decent case are also needed. For Blu-Ray, just the drive.
Software, depends on what you are doing and what you can afford. There are a lot of freeware programs out there that will do as good as payware.
Since you ask specifically about editing, that type of program can be a major expense. That's why I suggest looking into some freeware programs first.
If your computer is 5 years old, then you are overdue for a upgrade. Set a $$ limit and see what's out there.
JMO, But:
Choose a CPU first, then a motherboard, then the case, power supply, memory and other peripherals like hard drives (SATA preferred), and optical drives.
Most likely you would want to assemble a computer or have some one do it for you if you have specific needs.
I will let others give specific suggestions, but you need to do a fair amount of study on the parts to make informed decisions.
And welcome to our forums.
I want to buy a laptop that will do the job editing AVCHD
By kippard in forum EditingReplies: 20Last Post: 23rd Oct 2010, 15:28 -
Editing AVCHD with this computer - Possible or not?
By v1ru5 in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2010, 18:21 -
Don't buy...build your next computer!
By rcguy1 in forum Newbie / General discussionsReplies: 38Last Post: 17th Sep 2008, 12:12 -
New build video editing computer--- screen goes black.
By rcguy1 in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2008, 08:04 -
New PC Build for video editing
By kj1983 in forum ComputerReplies: 3Last Post: 29th Apr 2008, 11:30
