Hello,
I've asked this question in PHP support and mencoder support groups, in few forums, but noone can help me.
The thing is I'm trying to run Mencoder from PHP script. Everything works fine when I run it
from SSH, but it doesn't work when I run it from PHP:
First pass:
system("/usr/local/bin/mencoder -vf scale=448:-3,expand=448:336 -sws 9 -of lavf
-ovc lavc -lavcopts
vcodec=flv:vbitrate=250:trell:v4mv:mv0:mbd=2:cbp:a ic:cmp=3ubcmp=3:vpass=1
-frames 800 -ofps 24000/1001 -oac mp3lame -lameopts abr:br=64:mode=0 -channels 1
-srate 22050 -of lavf -lavfopts format=flv -o ".$outputFile."
/home/re/ff/logo7.avi ".$inputFile);
Second pass:
-ovc lavc -lavcopts
The PHP output is:
MEncoder dev-SVN-r25703-4.1.2 (C) 2000-2008 MPlayer Team CPU: Intel(R)
Celeron(R) D CPU 3.20GHz (Family: 15, Model: 6, Stepping: 5) CPUflags: Type: 15
MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with
extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x206e57e AVI file
format detected. [aviheader] Video stream found, -vid 0 [aviheader] Audio stream
found, -aid 1 VIDEO: [] 448x336 24bpp 23.976 fps 86617.4 kbps (10573.4 kbyte/s)
[V] filefmt:3 fourcc:0x0 size:448x336 fps:23.98 ftime:=0.0417
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3 AUDIO: 44100 Hz, 2 ch,
s16le, 320.0 kbit/22.68% (ratio: 40000->176400) Selected audio codec: [mp3] afm:
mp3lib (mp3lib MPEG layer-2, layer-3)
================================================== ======================== OK,
exit Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1,
aspect: 0.000000, round: 1 Opening video filter: [expand w=448 h=336] Expand:
448 x 336, -1 ; -1, osd: 0, aspect: 0.000000, round: 1 Opening video filter:
[scale w=448 h=-3]
Opening video decoder: [raw] RAW Uncompressed Video VDec: vo config request -
448 x 336 (preferred colorspace: BGR 24-bit) VDecoder init failedOpening
video decoder: [raw] RAW Uncompressed Video VDec: vo config request - 448 x 336
(preferred colorspace: BGR 24-bit) VDecoder init failedOpening video
(preferred colorspace: BGR 24-bit) VDec: using BGR 24-bit as output csp (no 0)
Opening video filter: [flip] Movie-Aspect is undefined - no prescaling applied.
videocodec: libavcodec (448x336 fourcc=31564c46 [FLV1]) [VE_LAVC] High quality
encoding selected (non-realtime)! VDecoder init failedOpening video decoder:
[raw] RAW Uncompressed Video VDec: vo config request - 448 x 336 (preferred
colorspace: BGR 24-bit) VDec: using BGR 24-bit as output csp (no 0) Opening
colorspace: BGR 24-bit) VDecoder init failedOpening video decoder: [raw] RAW
Uncompressed Video VDec: vo config request - 448 x 336 (preferred colorspace:
Packed YUY2) VDec: using Packed YUY2 as output csp (no 0) Opening video filter:
[flip] Movie-Aspect is undefined - no prescaling applied. videocodec: libavcodec
(448x336 fourcc=31564c46 [FLV1]) [VE_LAVC] High quality encoding selected
(non-realtime)! VDecoder init failedOpening video decoder: [raw] RAW
Unknown 0x32565559) VDecoder init failedOpening video decoder: [raw] RAW
Packed UYVY) VDec: using Packed UYVY as output csp (no 0) Opening video filter:
Planar 444P) VDec: using Planar 444P as output csp (no 0) Opening video filter:
Planar 422P) VDec: using Planar 422P as output csp (no 0) Opening video filter:
Planar YV12) VDec: using Planar YV12 as output csp (no 0) Opening video filter:
(non-realtime)! VDecoder init failedOpening video decoder: [hmblck]
Hauppauge Macroblock/NV12/NV21 Decoder VDec: vo config request - 448 x 336
(preferred colorspace: Unknown 0x0000) VDec: using Planar YV12 as output csp (no
0) Opening video filter: [flip] Movie-Aspect is undefined - no prescaling
applied. videocodec: libavcodec (448x336 fourcc=31564c46 [FLV1]) [VE_LAVC] High
quality encoding selected (non-realtime)! VDecoder init failedOpening video
decoder: [hmblck] Hauppauge Macroblock/NV12/NV21 Decoder VDec: vo config request
- 448 x 336 (preferred colorspace: Unknown 0x0000) VDec: using Planar YV12 as
output csp (no 0) Opening video filter: [flip] Movie-Aspect is undefined - no
prescaling applied. videocodec: libavcodec (448x336 fourcc=31564c46 [FLV1])
[VE_LAVC] High quality encoding selected (non-realtime)! VDecoder init failed
Opening video decoder: [hmblck] Hauppauge Macroblock/NV12/NV21 Decoder VDec: vo
config request - 448 x 336 (preferred colorspace: Unknown 0x0000) VDec: using
Planar YV12 as output csp (no 0) Opening video filter: [flip] Movie-Aspect is
undefined - no prescaling applied. videocodec: libavcodec (448x336
fourcc=31564c46 [FLV1]) [VE_LAVC] High quality encoding selected (non-realtime)!
VDecoder init failedOpening video decoder: [raw] RAW Uncompressed Video
VDec: vo config request - 448 x 336 (preferred colorspace: Planar I420) VDec:
using Planar I420 as output csp (no 0) Opening video filter: [flip] Movie-Aspect
is undefined - no prescaling applied. videocodec: libavcodec (448x336
VDec: vo config request - 448 x 336 (preferred colorspace: Planar YVU9) VDec:
using Planar YVU9 as output csp (no 0) Opening video filter: [flip] Movie-Aspect
VDec: vo config request - 448 x 336 (preferred colorspace: BGR 24-bit) VDecoder
init failedRead DOCS/HTML/en/codecs.html!
Exiting... MEncoder dev-SVN-r25703-4.1.2 (C) 2000-2008 MPlayer Team CPU:
Intel(R) Celeron(R) D CPU 3.20GHz (Family: 15, Model: 6, Stepping: 5) CPUflags:
Type: 15 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU
with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x206e57e AVI
file format detected. [aviheader] Video stream found, -vid 0 [aviheader] Audio
stream found, -aid 1 VIDEO: [] 448x336 24bpp 23.976 fps 86617.4 kbps (10573.4
kbyte/s) [V] filefmt:3 fourcc:0x0 size:448x336 fps:23.98 ftime:=0.0417
[scale w=448 h=-3]
Exiting...
I wonder how can I fix it? Is it PHP bug or Mencoder bug?
Results 1 to 1 of 1
Mencoder+PHP No streaming :(
By diduafka in forum Video ConversionReplies: 6Last Post: 3rd Aug 2011, 04:45 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
mencoder : my command doesn't work
By n2turtles in forum DVD RippingReplies: 5Last Post: 2nd Jan 2010, 22:57 -
php error - viewforumlatest.php?topicdays=1&start=100
By offline in forum FeedbackReplies: 9Last Post: 29th May 2008, 23:52 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
ubcmp=3:vpass=1
Opening
