Does anybody know how to remove a stuck tape in a sony ccd-trv608?
I popped the tape in and it closed halfway then a yellow arrow up with a line under it popped up on the LCD.
Now the tape won't come out.
Please help?
First thing I'd do is to turn off the camera and unplug the power. Wait a few minutes and plug back in. It might just reset itself and kick the tape out.
Hi, thanks for responding. I've reset it a couple times with the reset button. The guide lifts about 5 cm then stops and doesn't eject. Then I have to reset to make it go back down.
Well, I can see the tape is destroyed inside the carriage. I took the carriage cover off to investigate and the tape is ripped. Basically spinning around when I try to rewind or fastforward. But the tape refuses to come out of the carriage
I would take it to a shop you, or someone you know REALLY well, trusts!!!
Doing it yourself with no presumed background in this sort of thing can destroy the tape or the heads or all.
Good luck. -
Well, tapes destroyed. I can see that perfectly. Could care less about the tape now. I just want the tape out.
What kinds of sounds do you hear when the guide moves? Does it sound like something is hindering the mechanism?
EDIT... Oooh. Nevermind. -
just a few feet of tape is gone...can be spliced
as mentioned, if you plan on using this cam in the future, take it to a reputable shop as you'll need to find the cause anyway...and get it repaired properly
if you get the tape out yourself, you'll be tempted to insert another without finding out why the first tape goofed...
<edit> wait a sec...isn't this a new camera? just may be a cheap tape that's binding. if so, you can try running them back and forth from start to finish then back again to loosen the tape within</edit>
Tape stuck in Sony Video8 camera
By ldemer in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2011, 18:05 -
$250 to a get a stuck tape out of a Panasonc AG-EZ50U camcorder?!
By zlzabayle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 19th Jul 2010, 17:50 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 22:06 -
Mysterious problem with hi8 tape playback!
By cecile in forum Capturing and VCRReplies: 6Last Post: 12th Mar 2009, 18:18 -
Hi8 tape to Digital
By kj1983 in forum Capturing and VCRReplies: 9Last Post: 19th Aug 2008, 18:33
