Hey guys,
I have a problem, when I add subtitles to convertxtodvd the subtitles are distorted. See this pic:
After searching many threads it doesn't seem too many other people have the same problem. Anyone know why I have this?[/img]
				Results 1 to 14 of 14
	Did you try to change the settings within convertxtodvd?
 Settings / Subtitles --- Text subtitles rendering settings.
 Futz around with the Font (make it smaller?), color, Etc.
	I've used ConvertXtoDvd since forever but i have never used it with subtitles.
 But they have a new beta version out for testing....
 https://forum.videohelp.com/topic344375.html
 Look's like they have added many new options and tweaks for user's to use.
 I have it but i have not installed it yet to test or check it out but maybe they have some more options for playing with sub's ?
	I didn't try that, but why would my subtitles look like that anyways? hmm or could it be they don't support that format. Because the subtitle looked okay it was a sub/idx file, but for .ass and .ssa it looks distorted or either the subtitle increases by like 3x the sizeOriginally Posted by GideonK If I can find a program to convert .ass or .ssa you think it would work? Or was anyone with .ass or .ssa able to get it to work? If I can find a program to convert .ass or .ssa you think it would work? Or was anyone with .ass or .ssa able to get it to work?
	Are you making switchable subs in ConvertXtoDVD, or are these hardsubs ? Read my blog here.
	They are switchable subs. Don't have a problem with hardcoded subs. I tried d/ling subtitle workshop (heard it was the best and most complete) but it can't save as the .sub/.idx pair?Originally Posted by guns1inger
	I usually use srt subs in ConvertXtoDVD and have no problems. You can adjust font sizes etc before you encode. Read my blog here.
	I'm confused. What subtitle file are you trying to open in convertxtodvd that looks bad? what extention does it have?
 Did you create it yourself? Downloaded? Please clarify.
	Hi, sorry to confuse, I mentioned the troubles with file types in the 4th post. They are .ass or .ssa file that are not working. The .idx/.sub pair has worked for me though. I heard that not many programs completely support .ass so that may be the problem, so I am trying to convert .ass to .idx/.sub and see if that works, but there doesn't seem to be a program that will do that.Originally Posted by GideonK
	ConvertXtoDVD supports .SRT .SUB/IDX and .SSA/.ASS subtitle files.
 Keep in mind that SUB/IDX subtitle files are graphic (bitmap) formats and cannot be changed in ConvertXtodvd while .SRT and .ASS files are text based and can be rendered within convertxtodvd.
 If you want to convert your .ASS subtitle file to SUB/IDX here is how you do it:
 download vobsub and use the subresync tool that came with it to load the .ASS file and than save it as an .SRT file.
 (file.ass will be saved as file.ass.srt you can just rename it as file.srt)
 download SubtitleCreator, load the .SRT file and than file / save VobSub, This will create a SUB/IDX combo.
 If you're not sure how to change a subtille file (SRT and ASS only)in convertxtodvd then post
	Another way: convert .ssa to .son via MaestroSBT,
 then convert .son to .idx+.sub with son2vobsub
 (worth the effort only if you really need to keep the superior
 formatting-capabilities of the SSA file format).
	Ok, I tried that, but some reason my subs are still don't look good, the letters are kinda blurry. Could it be something wrong with my PC?Originally Posted by GideonK
 edit: Also, the settings don't stay. The subs were in Comic sans and some subs were at the top now moved to the bottom, everything went to default with cxd settings Tahoma.
 Not sure how to use maestroSBT, its not too newbie friendlyOriginally Posted by Midzuki What are the steps to do that? What are the steps to do that?
	I don't think anything is wrong with your PC otherwise all files would look blurry. Could you cut a tiny fragment of this file and upload it to a site so we can take a look at it?
 Also, what steps are you taking to change the fonts and size in Convertxtodvd?
 Could be that your file is a little funky to begin with, not sure.
	How do I cut a piece of the file? But I don't think its a problem with just that file, because I tried many different ones and they all turn out to look blurry/jagged. When I am changing the fonts in cxd I am creating a new style and applying it as the default, but I don't really want to do that. I prefer to keep the style of the original subtitles.Originally Posted by GideonK
 The one that worked was this file that has .idx/.sub it has yellow looking text and it didn't turn blurry after converting since like you said its a graphic. All the other types of files .srt .ass .ssa somehow do not turn out good. The SRT files since they are text files with no style will take the default style that cxd offers and it will be a little blurry and jagged. The .ass subs that have a lot of style get more jagged and blurry than SRT. Most of my ssa subs somehow get enlarged by around 2-3 times the size of the original. I have been doing a lot of searching and no one seems to have this problem, so I am wondering what's wrong. That's why since I know idx/sub works pretty good, I wanted to try to convert any subs to that format. But I tried your method and it didn't work.
  subtitles and convertxtodvdBy babeflover in forum SubtitleReplies: 4Last Post: 30th Nov 2010, 22:24
  Subtitles and ConvertXtoDVD 3By sissyfoot in forum SubtitleReplies: 1Last Post: 10th Nov 2009, 23:14
  Heb Subtitles in ConvertxtoDVDBy eliqush in forum SubtitleReplies: 0Last Post: 15th Jul 2009, 03:10
  Subtitles in ConvertxToDVDBy lanooz in forum Authoring (DVD)Replies: 0Last Post: 4th Nov 2008, 10:07
  No subtitles with convertxtodvd !!By hilario in forum SubtitleReplies: 2Last Post: 9th Jun 2007, 19:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
