I wonder if it's possible to create an image sequence of the individual frames out of the HDV captured (1080p 60i format video) from a Sony HC3 camcorder, if so what software could I use to this end?
Originally Posted by zoobie
If you want to go the free route, you can open the m2t in DGindex and save the project d2v. Open the d2v in Virtualdub and save the selected image sequence to BMP or JPG. Easy and free...........
If you'd like, you can then Batch Resize the 1440 x1080 image sequence to 1920 x 1080 with Irfanview (also free)..........Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 23rd Dec 2011, 20:44 -
how to convert BMP to AVI ?
By monks19 in forum Video ConversionReplies: 2Last Post: 2nd Apr 2010, 15:08 -
receiving bmp using hyperterminal
By emenent in forum ProgrammingReplies: 0Last Post: 24th Sep 2008, 00:45 -
From HDV shooting to HDV watching
By MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Apr 2008, 13:05 -
Q: Extracting narrow horiz strip from every Nth HDV frame
By j_hall in forum ProgrammingReplies: 0Last Post: 5th Apr 2008, 18:57
