Hi![]()
I have a laptop that is set up to turn to screensaver after 5 minutes of inactivity, and turn off the screen completely after 15 minutes of inactivity.
That should take care of the screen. How about the computer itself? What is the safe amount of time I should leave it on without killing it? I am using WinXP.
You should be able to leave it on as long as you want, really. If you are concerned about heat you can get a cooling base, which is a platform that has some fans which the laptop sits on.
When not in use I always turn mine off and turn off the power bar its attached to, not so much because of the laptop but more because of the AC adapter. I never truly trust those things. When I'm working on laptop or rendering something on it, I don't worry how long its on.
D. -
As long as it has space for ventilation you should be able to leave it indefinitely, in theory. I use mine for 7-8 hours a day for the last 8 months and have no heat problems. Just leave it on a flat surface where the hot air can escape as designed.
As suggested already, if you are truly concerned get a cooling base. -
Thanks.
There is plenty of space for ventilation underneath my laptop.
Killing some unwanted clips
By jairovital in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2010, 08:22 -
Power cuts killing PC
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 11th Feb 2010, 08:55 -
new anyvideoconverter freeversion 3.0.1 is killing me.Need help please!!!!!
By tendra in forum Video ConversionReplies: 3Last Post: 16th Dec 2009, 07:27 -
divx 6.6.1 is killing me. upside down video
By yandao87 in forum Newbie / General discussionsReplies: 4Last Post: 5th Aug 2007, 12:33 -
Bollywood movies keep killing my DVP5982
By gene0915 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jul 2007, 10:16
