Does any one know/recommend of an all in one software package that will encode and burn the PAL DVD to NTSC DVD with out having to use multiple programs or is there a one touch side by side DVD duplicator/recorder that will take a PAL and burn a NTSC on the other side - Thanks for any assistance![]()
Not that preserves the menus or encode the extras. To do that you have to pull it apart, re-encode, then rebuild. No automated method.Originally Posted by richards2222
If you are happy with just converting the movie, ConvertXtoDVD can do a reasonable job, and FAVC can do a much better quality conversion, albeit in a slower time do tot he quality of the encoder involved.Read my blog here.
You will get better result buying < $50 PAL/NTSC player than a convert for the same price
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 18:30 -
PAl to NTSC dvd projects - Conversion
By bpinto0805 in forum Newbie / General discussionsReplies: 1Last Post: 31st May 2009, 03:10 -
PAL DVD to NTSC Conversion (read as much as I could)
By DW in forum Video ConversionReplies: 3Last Post: 27th May 2008, 03:42 -
PAL to NTSC DVD Conversion Problem
By squallx404 in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2007, 06:16 -
PAL To NTSC DVD conversion takes 6+ hours???
By lnong in forum DVD RippingReplies: 4Last Post: 12th Jul 2007, 02:56
