Can you use a video clip as a transition for the menus in DVDLab Pro?
A question: I wanna create a button whichg links to the transition movie and thenOriginally Posted by guns1inger
to the next menu, I have 3 buttons using the same transition clip, do i need to create
3 identical clip in the movie corner? -
Yes, you will need three instances of the same clip. Just create three movie assets and drag the same clip to each of them. If you know how to code, you might be able to program it so that only one instance is required. Set a register value as a POST command on the button press, then code for which menu to call after the clip based on the value set before it was called. However it is easier just to have 3 clips most of the time.
Read my blog here.
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 05:13 -
Importing menu transitions from a DVD to another with DVDLab Pro
By lorix in forum Authoring (DVD)Replies: 7Last Post: 6th Nov 2008, 12:52 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 22:26 -
DVD Lab Pro - Question about movie merge
By shashidar in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 15:41 -
DVD Lab Pro chapters question
By jesterhud in forum Authoring (DVD)Replies: 9Last Post: 23rd Aug 2007, 18:06
