I converted a dvd to xvid but it was episodic and all the epeisodes were in the same pgc. I split the avis after the fact with virtualdub but there is one more avi and when the next season comes out I don't want to split 4 files by hand. Note the avis vary in legnth eliminating auto cuts based on time. Is there another way to split the video either before encoding to xivd or after?
Hi-
Yes, you can split before encoding, when decrypting. If all are in the same PGC, then choose the number of chapters corresponding to each episode. For example, set up DVD Decrypter for IFO Mode. If there are 4 episodes and 20 or 21 chapters, then each episode consists of 5 chapters. Choose chapters 1-5 for ep 1, chapters 6-10 for ep 2, and so on. -
thats the same problem i'm still splitting by handOriginally Posted by aedipuss
I can't believe i didn't think of thatOriginally Posted by manono
are there any other suggestions before i hide in the corner
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
need some opinions on this auto level option for fixing a video
By mazinz in forum RestorationReplies: 6Last Post: 10th May 2010, 22:43 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
Auto edit DVD music video
By aril in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2007, 13:12
