Results 1 to 9 of 9
howdy case:
Cheers thanks ya : I will give this a try
and reports back indeed;
Enjoy weeks end
Cheers: -
Howdy Case
1st attempt went fast and no audio or subtitles -
though in preview it played great
2nd attempt now - details-
Source format - AVI , mpeg4 mp3 - target format- avi DivX mpeg4 mencoder
mpe audio - in Filters - I checked VOB subtitles- 10 - Burn ( you mention .srt- this will be 3rd try )- Loaded from subtitle file I downloaded with original avi file- font size 2
can I do this better or different - a noob to FFmpeg
Cheers in advance -
My first impression was that you aimed for DVD-Video, but your conversion is AVI to AVI?
Is your subtitle file in SubRip format (foo.srt)?
The loaded subtitles have to be a text based format (usually <200kB), not an image based format like idx+sub (usually >1MB).
Only check 'VOB subtitles' if the source file is a VOB with embedded subtitles, which you aim to use.
The top line is (VOB subtitles, stream no, format) is ignored for loaded subtitles in the second line.
Explanation of the items in the Filters tab.
How to convert to DVD with selectable subtitles. -
Howdy Case :
the file I have is avi with QT icon - plays great but only in German - the subtitles file for the film is separate file
with VLC icon - Subtitle file - 3.8mb , no file format - but when opened in VLC and I get info ( apple " i " ) under information - 30 streams appear - under stream 0 - reports "codec" spu , language - english , type- subtitle
the QT file played in VLC plays fine fine - no subtitles - yet played in MPlayer - I get the subtitles
any ideas ?
cheers -
Unfortunately, ffmpegX won't use VobSub for input in conversion.
Maybe you can find a SubRip (.srt) version of the same subtitles somewhere else? -
howdy Case:
cheers ya for the detailed explain- still only lists as a .sub file
Ill peek around and see what I can find
Cheers
Subtitles: diferent fonts, separate files, interpretable by DVD player
By Ze Tomes in forum SubtitleReplies: 17Last Post: 13th Jul 2010, 20:29 -
Merging Video Segments with Separate Subtitles
By thomasj in forum Authoring (DVD)Replies: 2Last Post: 24th Apr 2010, 07:40 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:26 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 03:50 -
Separate Subtitles using AutoGK
By gl22 in forum DVD RippingReplies: 5Last Post: 27th Jul 2007, 12:25
