I want 2 audio tracks on a VCD or on XVCD. I think that i can use te right and left chanels to put on every one a diferent audio track. Is that posible? How?![]()
thanks, but .. how?
I need a vcd not a svcd. my dvd player don't play svcd
I've trayed with bbmpeg whith an mpeg (mpeg1) and two streams of audio and at the mpeg result only put one stream.
what can i do?
thanks -
It cant be done, you cant have 2 audio tracks on an mpeg 1 as far as i know.
Have you tried making non-standard SVCD's? Nero has the option to do this, after you select SVCD, click on make standard. Its something like that, i cant remember off the top of my head -
It can be done.
- You take your two stereo audio tracks, flatten them to mono, and remix them so track one is coming from the left channel and track two is coming from the right.
- Switch back and forth using the Audio button on your DVD player's remote.
I have found freeware called Audacity that'll do the trick. I recently ripped the Highlander DVD and included the regular audio (left) and the director's commentary (right). -
The easist thing to do is go MPEG2. MPEG2 supports multiple audio tracks, MPEG1 does not. You can make one track the left channel and to the other right, then burn the single audio track but I find this to be more of a pain/effort than just muxing an xSVCD. But to each his own
Vejita-sama,
MPEG-2 is out of the question.
Quim's player doesn't play (x)SVCD.
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
--> Adding Audio CD Tracks to DVD audio ? <--
By MJPEG guy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 16:45
