I took about 4 min of dv and laid audio to it and the encoded it to .wmv . It came out to 104mb, which is too big to get on the internet. When I got to make movie it shows that it should only be about 14mb, what am I doing wrong?
I was able to down convert it to 11.5mb, @ 786 kbps. How do I do this in Vegas, without using an outside converter?
When you click on File -> Render you can chose which container to render to. If you click on the Custom button you can then chose what codec, and over-ride any preset values with custom ones. If you change the bitrate here, you will affect the file size.
It's all in the manual and help files.Read my blog here.
Thank you, I didnt find anything in the manual for the advanced settings you were speaking of. I'll check in help files after this test. Is there a way to set the rendering size and then the prog. sets the birate accordingly? I know I need it to be .wmv and 20mb or under to post to the website. I'll look for more info on settings for rendering as.
when using the bitrate Calc., My target codec is .wmv. ANy recomendations
Nevermind I think I got it.
I guess the only other question I have now is 512kbps the max bit setting without going into hd templates, in .wmv
Vegas Studio Plat: DVD files to HD?
By OldNick in forum EditingReplies: 71Last Post: 2nd Apr 2012, 18:38 -
What Are The Essential Plugins For Sony Vegas Movie Studio HD Plat PS 10?
By V Bot in forum Authoring (DVD)Replies: 3Last Post: 10th Apr 2011, 19:59 -
New Vado HD 3rd Generation - Vegas Studio 6 Plat - Audio But No Video
By videovinnie in forum Portable VideoReplies: 6Last Post: 16th Apr 2010, 20:56 -
Final product not satisfactory!
By ingeborgdot in forum Authoring (DVD)Replies: 14Last Post: 8th Sep 2008, 23:09 -
Looking for online training Course In Advanced editing with Vegas 8 Plat.??
By Jensen in forum EditingReplies: 3Last Post: 27th May 2008, 06:32
