Pls help, havinga problem in adobe encore on the building process
on the building progress - building navigation - building system files(sorting) part an error message pops up
Adobe Encore
! access denied
pls help. my movie is about 3 hrs more than 6 gb so im using dual layer dvd. as far as im concerned al settings are correct. cant fix the pro pls help
Results 1 to 9 of 9
I have enough space and yes i am in the administrator acount.
in the right place? sorry i cant understand i am exporting directly to a dvd DL.
thank you very much I hope you can help me Thanks again -
It still has to build the disc on your HDD first, before burning. Even if you tell it to burn to a DL at the end of the process, the whole structure has to be created on the hard drive first. If you don't have the space for the intermediate working files, or the finished structure, you won't get a disc.
Read my blog here.
Thanks Im sure that I have enough space on my Hard drive.
I cant ifgure out the problem -
I never had any problems with Encore and I have been using Encore for some time now. I am not sure if you wish to try Reinstalling Encore.
I am having this problem now when creating a DVD, not BD.
I have initially authored a disc and exported as Blu-Ray - worked perfectly.
Now I want to create a DL DVD of the same project, so I went to project settings, changed everything to DVD, and clicked on "build". Encore transcoded all the media again as expected, but when trying to create the navigation stuff, the message
"access denied"
pops up and windows says it has crashed.
Please, has anyone figured out any possible way to clear this out ?
Thanks,
Zetti -
See this from the Adobe KB:
http://kb2.adobe.com/cps/407/kb407236.html -
Can't Open Encore
By koberulz in forum ComputerReplies: 0Last Post: 4th Apr 2012, 03:53 -
Encore enutv-2
By smartel in forum Capturing and VCRReplies: 2Last Post: 15th Jan 2011, 17:15 -
11 Extra GB in Encore
By koberulz in forum Authoring (Blu-ray)Replies: 3Last Post: 6th Sep 2010, 07:08 -
Encore Questions
By ehill in forum Authoring (DVD)Replies: 3Last Post: 26th May 2009, 09:52 -
Help in Encore
By sk8_aholic in forum Authoring (DVD)Replies: 0Last Post: 13th Nov 2008, 01:33
