Hi Everybody:d
there is a problem with demuxing my dvd.I have residual A/V sync problem and i want to use some guide i red in this site about resampling the audio.
but when i demux and play the video(or audio) with real player it shows the length of file about 50 minutes(it's about 2 hours)and when i open it with powerdvd there is about 1:40.but if i direct stream it there is no problem!
used TMPGEnc and multiplexed the Demuxed Files,the Created MPEG file has nothing wrong with length,but the Sync Problem gets bigger.
P.S:i just tried the multiplexing with Direct Streamed files and the sync problem getting bigger is same here.
this is the name of my demuxed audio file:
VTS_01_1 - 0x80 - Audio - AC3 - 5ch - 48kHz - 16bit - English - DELAY 967ms
is there somthing wrong with the (DELAY 967ms) part?
Sorry for my Lousy english.
	The Delay specified here is the amount the audio is out by, hence you sync problem. If you adjust it by that amount in the right direction, you should have everything back in sync.
 How did you demux the files ?
 Are you sure you demuxed the entire title, and not just one VOB ?
 What does g-spot say about the source (VOB) and demuxed video ?Read my blog here.
	thanks for helping an iranian(a.k.a Al Qaeda  ) )
 i inserted silence and now converting it to mp2 to multiplex for test.
 <<Are you sure you demuxed the entire title, and not just one VOB ? >>
 what do you mean?i have the entie video and when i import it to DVDlab the time is right.
 i even tried it with my copy of Sunset Blvd.the demuxed files(video or audio) and it's all same.
 i think there is something with the program i open these files with.
 when i open the Sunset Blvd. Video with real player,it shows the Length 55 min but when i open it with powerdvd it's 2 hours and half!but the multiplexed file is 110 min(with every program)(and it should be!)
 i didnt install the K'Lite codec pack on my new windows,you think it will make any differences?
 and thanks for the delay thing,now everything is like on Disc Version,but there is another issue,after resampling(if it works)dvd lab wont compile it and will say your audio have to be fit 48khz,then what do i do?
	Personally, I don't believe any codec pack is worth the trouble they can cause.
 I also wouldn't install Real Player on one of my machines, or trust anything it has to say about video.
 You can alter the delay in DLP, so I would load the original audio from the demuxed disc, then use the Tools -> Audio Delay function to alter the audio. DLP will add the delay and make sure your audio remains compliant.Read my blog here.
  Problem with demuxing .ts fileBy iXed in forum DVB / IPTVReplies: 5Last Post: 8th Aug 2010, 10:14
  Demuxing ProblemBy jpmccusa in forum Authoring (DVD)Replies: 8Last Post: 18th Mar 2010, 20:10
  Demuxing Question/ProblemBy hizzy7 in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2010, 11:28
  Demuxing DL problemBy calanda in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 00:52
  Video demuxing problemBy larrym in forum Newbie / General discussionsReplies: 7Last Post: 30th Aug 2008, 12:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
