Results 1 to 12 of 12
  1. i encode my own dvd (dvdrebuilder)
    i want to re-backup some of my old dvd movies that i encoded
    when i try to copy them using nero or dvd decrypter, it gives me error - possibly small scratch on the disc
    is there another software u guys can recommend that does a better job of copying dvd
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    First try cleaning the disc, detergent, rinse, pat dry.
    Try Isopuzzle.
    If it fails on some sectors and you can see scratches, I've had success rubbing them down with Brasso. This is an abrasive, it will take the shine off, but should still be readable.
    Brasso is an abrasive that will likely make the disc worse than it already is. Search the forum for a big conversation on this topic a while back.
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Yeah, if by "big conversation" you mean you being an obnoxious insulting jerk, over and over.
    I SAID it is an abrasive. FFS. That's how it works.
    Have you actually dirtied your hands to experiment? I did. I made measurements of readability before and after.
    Last one I tried went from 94% to 100% recoverable data after a few minutes polishing.
    It works.
    When you give people advice, it's generally expected that you tell them of the dangers of using a method, if any exist. The only "jerk" here is the person that doesn't seem to care if his advice further damages the disc.
    - Brasso is basically liquid sandpaper.
    - Your human hand motions are too chaotic to give a smooth buff.
    - The odds are NOT in your favor. Screwing up the disc is more likely.
    Lots of other people had to learn this the hard way already:
    http://www.google.com/search?hl=en&q=brasso+%22not+work%22&btnG=Search
    If you really want to to fix a disc, take it to a place that re-buffs a disc with a professional machine.
    If you don't actually care about the disc, sure, attack it with Brasso.
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    It's worked for me several times so far.
    Disk that were unreadable are now readable.
    So, as far as I know, the "dangers" exist only in your mind.
    So again, have you actually tried it? Or are your opinions based on divine revelation?
    http://www.google.com/search?hl=en&q=brasso+%22not+work%22&btnG=Search.
    Yes. Try reading the links. Mostly people trying to buff their iPod screens.
    I'm sure there are lots of things that Brasso "does not work" for.
    I wouldn't advise you to polish your teeth with it.
    After a few pages I found one that actually did refer to discs.
    http://www.ehow.com/how_2001533_remove-scratches-cds-dvds.html
    Step One
    Wrap the rag around your index finger and apply a small amount of brasso to the rag
    Step Two
    Polish the scratched area in a circular motion applying a small to medium amount of pressure
    Step Three
    Using a clean part of the rag, wipe off all traces of the brasso polishing compound
    Step Four
    Try playing the CD or DVD disc in its appropriate player
    Overall Tips & Warnings
    Typically the scratch does not have to be entirely erased for the disc to be returned to playable condition
    Patience is key, polish for a minute or two and try to play the disc. If it still does not work, repeat the steps.
    Brasso is a very fine polishing compound, if you apply too much pressure you may add scratches to the disc instead of removing them
    Well, was that "the hard way"?
  7. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    The main thing is that you should give a warning with your advice. Have we so long forgotten the lesson of "Format c:/"?*
    Saying "it's an abrasive" is not the same as "this is like sandpaper. Use wih extreme caution!"
    *Do not try this! (even though it will do nothing).
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Do you want me to create a new thread for you guys, where you can discuss "Is Brasso the answer to the scratched disk problem?"
    /Mats
  9. thanks for the help guys
    i will definitely try all ur suggestions
  10. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Because it's NOT like sandpaper.
    I hate to be repetitious, but have you actually tried it?
    If not, what are you basing your remarks on?
  11. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    /Mats
    If I needed that I could just hit my head with a hammer by myself.
