1 part of my job is file conversion and creating links, and I received a request to convert a WMV to .MOV - DVCPro_NTSC. When I drag the file into Sorenson Squeeze, I receive this error:
"Unable to add the source file(s). The following file(s) are not supported." And then it lists the name of the file I tried to drag in there. Below is info on the WMV file.
File Type: Windows Media Audio/Video
Bit Rate: 5435 kbps
Dimensions: 720X480
When i try to open the WMV it wouldnt play and I received an error message saying I was missing the WVC1 codec. I had the IT guys install WMV11 and or that codec because now I can view the files but I still can't bring the WMV into Sorenson Squeeze. If more info is needed on the WMV, please let me know how I can find it.
[/img]
If this is on a mac, you will need to buy WMV Studio from
Flip 4 Mac, and you can do it natively in QT Pro.
Done it a couple of times, works fine."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I don't know what the problem is, but I couldnt drop the file into Sorenson Squeeze on the PC and Episode on the Mac didn't like the file either but I opened it with MPEG Streamclip and that did work. I then exported to MOV with the DVCPro NTSC setting.
Problem converting videos from MPeg4 to wmv
By TomH309 in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2012, 09:30 -
Problem with wmv converting ffmpeg codec id 86056
By Pika in forum Video ConversionReplies: 2Last Post: 15th Jul 2009, 15:29 -
Problem converting .wmv file
By AdamUK in forum MacReplies: 3Last Post: 24th Apr 2008, 07:40 -
Converting AVCHD to wmv
By Roddytoo in forum Video ConversionReplies: 0Last Post: 20th Feb 2008, 11:15 -
Converting to MP4 from WMV problem
By tlxi228 in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 06:36
