    Jan 2008
    I have WM recorder and I input the URL of a video I want to capture. It is 50 minutes. WMRecorder captures the first part which is 11minutes but then it stops.
    The site I watch the broadccasts from breaks the program in section - first part 11 minutes, second part 10, third part 10 and last part 9 minutes. As one section ends it automatically goes on to the next part.
    How can I capture the whole broadcast? I wrote to WMrecorder to ask but no one responded.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The URL changes for each segment. You will have to download all of the segments and manually put them together.
    Google is your Friend
    Jan 2008
    I know that. My problem as I said is not in joing the segment but rather in downloading them. The url in the window does not change for each segment.
    My question was and still is How do I capture the entire broadcast. It will only capture the first part no matter which section is playing.
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Sorry, I misunderstood what you are asking.
