Up until fairly recently, I've mostly run basic business app.s, internet stuff (browsers, media players), basic video-related app.s like Shrink or Decrypter, etc. Nothing that made particularly high demands of a PC's graphics hardware. At the same time, for a few things -- like attempting to play hi-def trailers at the Apple Quicktime site -- it was immediately clear that the video-chip built-in to my last MB (with its 32MB of memory) was not compatible and could not begin to cut it. I haven't bought a video card in years, the last one being an old Matrox dual-head, which I liked a lot.
Now that I'm looking at building a new system, and thinking in terms of not limiting myself with something inadequate, I'm wondering just what sort of video card is quite sufficient for hobbyist (not pro) level video editing, your more demanding video app.s (whatever they might be), or being able to play hi-def material ? (I'm probably not going to change the computer monitor just to see those clips in hi-def; I just want to be able to play the video without it crashing the hardware.) So, I'm looking for recommendations. Is 128M of onboard memory sufficient, or do you need 256 ? I've seen graphics cards being sold with over 512M, but that sounds like overkill for anyone who is not a gamer, and I'm certainly not. I've seen graphics cards that cost $500., which seems ridiculous to me. Also, I'd prefer to avoid anything that generates too much heat and requires really aggressive cooling solutions. What brands / models would you recommend that fit these parameters ? Dual-head would also be nice, but is not an absolute requirement.
Related questions:
Is Matrox still around, or have they gone totally over to the Mac ?
Does a board like the Hauppauge 250 or 350 double as a regular graphics card, and if so, how well does it fit the qualities mentioned above ?
Results 1 to 14 of 14
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
6 months old but a place to start:
http://www.anandtech.com/video/showdoc.aspx?i=3047
I use an nVidia 8600GT that I bought around 6 months ago for ~US$130.
Matrox is still around with multihead display cards. They're not competitive in the 3D market so you don't hear much about them. I don't think they have hardware h.264 and VC1 decoding.
Hauppauge PVR-250 and 350 cards are for video capture. You'll still need a graphics card for the display. -
You'll be disappointed to find that out throwing your money at a video card is right now a waste of money. HD stuff in WMV, Divx and MPEG-2 doesn't need it. H.264/X.264, which could use the help, in my experience can't really offload the job of processing to the video card, so the CPU is actually more important for HD playback.
Hauppauge does NOT make video cards. They make some great TV capture cards (I own the PVR-350), but that's all they do.
If you want to get a new video card as part of a new system build, unless you are a gamer you don't really need anything state of the art. 256 MB of memory on a video card is fine. And do be sure to use PCI Express in whatever card you get. AGP is old technology and not supported on the newer, better cards. You'll have an upgrade path with PCI Express at least, should it ever reach the point where the freakin' card can actually offload H.264/X.264 processing from the CPU. -
jman98 pretty much has it.
Beyond that I'd advise visiting other sites other than Quicktime for your hidef trailers. Anything associated with Quicktime is likely to yield poor results in the Windows enviornment. -
What OS are you planning?
For XP use 512MB minimum and 1GB nominal.
For Vista use 1GB minimum and 2GB nominal.
What kinds of compressed video are you planning to play?
MPeg2? Get NVidia 7600GT or better
MPeg4? Get NVidia 8600GT minimum for now but for HD H.264 or VC-1 you will want more later.
What kinds of video do you want to capture?
If SD analog cable or baseband the Hauppage PVR models are favored.
If HD ask more.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
@seeker47,
I have recently improved my graphics cards to use the 3D Window managers in Linux as well as increasing performance under Windows, I am not a gamer either. I have had good luck with NVidia FX5500's w/256mb they are cheap ($67.00CDN) and for the most part have worked great for both platforms and are capable of moderate gaming as well. Of course the cards already mentioned are better, but more expensive and perhaps overkill for your needs. Best of Luck! -
Hello,
I hope this is a related topic.
I am putting together an Intel Quad Core system based on the Asus Striker (Intel SLI) motherboard.
My basic concern is that I would like to still use XP Pro, rather than Vista at all.
So my bottom line question, because of not using Vista - should I stay away from DX10 graphics boards?
What might someone recommend for me, please and thank you.
[Considering what I have read in various threads so far, I am inclined to believe I should stick to DX9.0c boards. True?]Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
Not really related at all. Better to make a new topic.Originally Posted by painkiller
But don't worry, DirectX 10 cards are backwards compatible.Recommends: Kiva.org - Loans that change lives.
i think your level of usage you might be interested in this article: http://www.dailytech.com/article.aspx?newsid=10448
if you wanna game at all you'd wanna look more to the $200-$300 range(3850, 3870, 8800gt) but im pretty sure from what you're saying the cards in the article will pretty much take care of you.PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Thanks for the answer, EdDV.
But my concern is with regard to the use of such a card with WInXP.
In my various readings, I thought that WinXP can't use DX10, just Vista.
(Now I'm sure I understand that on the PC - I would install DX9.0c... but these new graphics cards that are DX10??? Are these integrating DX10 on the graphics board? Or implying use of DX10 as it is installed within the OS on the boot drive? This is where I am a bit confused. That and my readings say that Microsoft has no intention to upgrade/update WinXP to be able to use DX10.)
Eh, so I'm looking around but there are sooo many cards...
Which, when I noticed this topic, I thought I would start here at least.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
DirectX 10 is only available in Vista
see http://en.wikipedia.org/wiki/DirectX#DirectX_10
DirectX 10 is backwards compatible to DirectX 9c
DirectX 10 cards like the GeForce 8800 have drivers for for XP and DirectX 9c.
Thank you.
Cards that are labelled as dx10 are really "dx10 compatible". Meaning that the software designers can rely on them having certain features available (mainly hardware acceleration of hi-def codecs), over and above dx9 cards. However some dx10 chipsets are incredibly puny (intel and other integrated graphics) and you would be far better off with a decent dx9 discrete card. Dont try to think DX9 Bad (7900GTx2) vs DX10 good (INTEL igp x38) first one gets you 140fps in COD3, second gets you 3, maybe 4 fps.
The electronic components of the power part adopted a lot of Rubycons.
Video Card Recommendations needed
By Noahtuck in forum ComputerReplies: 7Last Post: 7th Jul 2010, 12:17 -
Seeking under $100 (USD) Video Card Recommendations
By sum_guy in forum ComputerReplies: 19Last Post: 28th May 2010, 19:59 -
Recommendations for a Video Card
By bryankendall in forum ComputerReplies: 6Last Post: 25th Feb 2010, 16:15 -
Upgrading video card. Any recommendations?
By seven_deuce offsuit in forum ComputerReplies: 15Last Post: 13th Jan 2009, 21:08 -
Recommendations for capture card?
By Big Chupa in forum Capturing and VCRReplies: 6Last Post: 12th May 2007, 21:24
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
