hello
i've recently captured a whole load of camcorder tapes as avi's and i now notice that there is an 'avi dv' option in my premiere program.
essentially, i was looking to capture as best quality setting - have i messed up or are they the same?
cheers!
Set project to DV and capture DV. That is an exact first generation copy of the data on tape. The only reason to capture uncompressed is if you are integrating DV clips into an uncompressed project.
If you capture to "AVI" you are capturing uncompressed or with an associated codec. This will not get you first generation quality and should only be done for good reason.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You have nothing to worry about.
The DV AVI option tells Premiere to use a DV encoder from MainConcept - generally regarded as one of the fastest and highest quality.
If you choose the other AVI option, you can select one of many encoders for different formats. One of them is the default DV encoder on the computer - using the Microsoft DV encoder.
Capture-wise, the encoder is irrelevant. The file on the disk will be the original DV data wrapped in an AVI "container".
The choice between the MainConcept and generic DV encoder comes when you render your project.John Miller -
With Premiere you can capture DV format yet have an uncompressed project. In that case your capture will be DV format and decompression is done when you render the timeline. I suggest you work in a DV project to prevent decompression.
hi thank you all. fyi - i ran the source foreg software and it came up with this:
1 video stream - sony dv
1 audio stream - PCM
first video stream 28 mbps 720/576 25 fps SONY DV PAL
first audio stream 1536 kbps 48KHZ 2 channels pcm
sound good?
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
