hello - can anyone advise on the following video related problem ?
Overview:
I got ULEAD STUDIO 9 and a TV/video capture card
I use a Hi 8mm analogue video camera
PC is P4 etc ( no DVD recorder)
DVD recorder is external using USB connection
had someone else make me a MPEG file of footage
Problem: 1
TV card captured footage but colours where not original to even what was viewed on ulead software, – in playback of recorded footage, the colours where too dark esp in shadow area
Thus I got someone else to capture and give me an mpeg file of footage – any idea way capture card would give bad colours , ie not original ? Does this constitute a “generation “ loss ?
Problem 2
Using the MPEG file recorded by someone else (of my footage) ….
I then edited the footage (taking out bits and adding text) and saved it using ULEAD studio – then also saved it with same software to HDD as DVD VOB files (an option in Ulead) – then I asked it (an option in ulead) to save to DVD disk – which it willingly did
However. The DVD has “mosaics” (blocky lines) at intermittent points in footage and at different heights – audio makes a scratchy sound when they appear …
The VOB files on the HDD are fine … makes me think problem lies in communications to DVD
HELP = can you advise ?
…. Why do you think I am getting mosaics ? what solution do you recommend ?
…. Could the problem be that USB is too slow to write to DVD a Video file (38min long)
…. Should I rather use firewire ?? is that 1348 or what ever it is called?
…. What cabling is best for recording / DVD cutting footage ?
ALSO…. I was thinking of recording the analogue footage to a DVD recorder (TV TYPE) with a HDD internal and then cut to disc , take to pc and edit VOB’s
Would that give a better quality footage and is it possible to do it that way ? comment ?
Hope you can offer some comment and solutions !
Thanks ... Newbie !
Results 1 to 1 of 1
Newbie wanting help? Import DVD/MPEG in Ulead VideoStudio
By Mark75 in forum EditingReplies: 4Last Post: 30th Oct 2008, 16:52 -
> Ulead VS11 Broken MPEG 2 Field order <
By Dark Alpha in forum EditingReplies: 8Last Post: 24th Jun 2008, 08:29 -
Ulead MPEG.Now Encoder Missing
By raouliii in forum EditingReplies: 1Last Post: 11th Dec 2007, 11:02 -
Ulead VideoStudio 9 Blurry MPEG encoding
By kevluigi in forum Newbie / General discussionsReplies: 6Last Post: 5th Jun 2007, 01:38 -
Ulead Movie Factory Issue / Mpeg files
By DVDdummy in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2007, 22:57
