Hi
Im still having trouble converting certain MKV to DVD with SYNC issue, (VSO ConvertXtoDVD)
is there a method of shifting the sound on affected VOBs?
I tried WMP CLASSIC with 50ms/100ms but when i save the file it was still the same, and also playback was stuttery (FFshow) and therefore I had to save and re-open in VLC to check
I have Virtualdub and nandub and heard it can be done in that...
Thanks Again Guys
You make it sound so simple -- i bet its not hehe...
I have encoded this file twice now with exact same problem at 1:16:00 in its out of sync by about 50-100 ms
thanks -
I fixed the issue... I used AVI2ISO to encode the file, had to disable 5.1 sound mapping then run encode, its a great program...
I think it should be submitted to this site for download....
http://avi2iso.planetaclix.pt/avi2iso.rar
Fixing DVD VOB so it's seekable
By Seraphic- in forum DVD RippingReplies: 3Last Post: 12th Jul 2010, 20:05 -
Fixing sync problem on rmvb
By gameroftheuk in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2008, 21:16 -
Sync issues after fixing with ac3fix
By mub6 in forum AudioReplies: 5Last Post: 24th Dec 2007, 07:56 -
Audio becomes out of sync when converted (transcoded?) from .vob files
By Neptuna_Fish in forum Newbie / General discussionsReplies: 12Last Post: 21st Aug 2007, 19:39 -
Need help fixing up already converted DVDs of old videos
By t_burrito in forum RestorationReplies: 1Last Post: 10th Jun 2007, 00:32
