I have several files loaded into Nero, edited and ready to burn. I go to add alternate commentary by hitting the microphone logo and selecting the file to save the audio, microphone used and audio compression.
I have used this microphone before on sound recorder just to test it out. I've even used it on previous versions of Nero Vision. When I hit "OK" to start the recording I get this error message.
What is up with my audio?
Obviously (and not surprisingly) the problem is with Nero. You have a couple of choices.
1. Download the latest version of Nero, as they are releasing bug fixes all the time.
2. Take the issue up with Nero support and see if they have a solution
3. Use something better. You can easily record your commentary in Audacity and bring it in for authoring later.Read my blog here.
Problems writing with nero vision express 3
By tatester in forum Authoring (DVD)Replies: 3Last Post: 11th Feb 2009, 17:38 -
Sudden problem with Nero Vision Express 3.1.0.0
By smackyourfupa in forum Authoring (DVD)Replies: 8Last Post: 3rd Nov 2007, 17:56 -
AVI won't run in Nero Vision Express 3
By loninappleton in forum Video ConversionReplies: 3Last Post: 9th Oct 2007, 14:33 -
better tha nero vision express
By cesarin in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2007, 14:34 -
join and burn using winavi and nero vision express?
By leogeo in forum Authoring (DVD)Replies: 9Last Post: 11th May 2007, 07:56
