Hi Folks,
I was given two batches of videos to make into a DVD, the vids are all .avi and fall into two groups:
512x384 (4:3) Video falls into the range 341 to 423 Kbps
624x352 (16:9) Video falls into the range 1,010 to 1,741 Kbps
I plan on using SUPER encoder to convert them to mpeg2 and was wondering if the following assumptions are correct if the quality is good enough:
For the 512x384 files because the video bitrate is low it would be better to set output to 352x240 (4:3)
For the 624x352 files because the video bitrate is higher it would be o.k. to set output to 720x480 (16:9)
Is there a general rule one could use to determine the best output resolution or how much is too much if converting to a higher resolution?
Everyone lies.
The innocent lie because they don't want to be blamed for something they didn't do, and the guilty lie because they don't have any other choice. -
Best way to decide is to make a series of short encodes, 2-3 minutes each. Same files with different settings; give each output file a name that reminds you of the settings. Then burn these to a DVDRW and see what you see.
I agree with AlanHK that testing the way to go. I suspect that your assumptions are pretty good in this case however.
If you have time, or a stonking great machine, you might want to look at VideoEnhancer to see if it can enlarge the video more effectively for you. However if the only machines you have available are those listed in your profile, forget it. Icebergs melt faster.Read my blog here.
Converting the 512x384 file to 352x240 will be throwing out a lot of the resolution. I'd go with 720x480 unless the source is really poor quality (the bitrate of the source alone doesn't necessarily reflect quality) or you're trying to put many hours on a DVD.
setting the correct colormatrix in x264
By codemaster in forum Video ConversionReplies: 1Last Post: 2nd Mar 2012, 22:14 -
Correct size Resolution for AVI
By Sliztzan in forum EditingReplies: 45Last Post: 25th May 2010, 10:01 -
Problem setting monitor resolution
By gll99 in forum ComputerReplies: 5Last Post: 16th May 2009, 07:17 -
Correct resolution for photos for DVD?
By Grunberg in forum Authoring (DVD)Replies: 3Last Post: 13th Nov 2007, 11:41 -
Sefy's Guide and Correct Setting for DVD (NTSC).mcf
By moviebuff2 in forum Newbie / General discussionsReplies: 8Last Post: 1st Aug 2007, 09:01
