Hello,
I've been using Vegas for a while now and this problem has be stumped. I'm unable to properly import MPEG-2 video recorded by a Sony HDD (MPEG-2) camcorder. The problem is that the video files alone are being brought into the project without the audio stream. The video files opened fine with Vegas 7, and they also play with proper audio through WMP (etc.) so it seems that 8 is the problem here. Any thoughts?
Results 1 to 11 of 11
Happy New Year everyone! :P
Did you register the software? -
What is the format of your sound?
I had a similar problem and it turned out to be that the sound was AC3 and I only had codecs for mp2/3 installed.
I used VOB2MPEG to stitch the VOBS off the DVD together onto the HD and then used Womble MPEGVCR to convert the sound (I know there are other ways but MPEGVCR also let's me cut ads stuff off tv)
There's probably something in the setup/options to sort it out as well but I'm lazy and can't be bothered to re-install to find out
Vegas usually supports mpeg 1 & 2 via a plug-in (which, in version 6, is the Main Concept MPEG 1 & 2 plug-in) which requires a separate "unlocking" procedure after purchase. Same thing applies with AC-3 support...AC-2, I don't know about.
If I was in your place, my first task would be to see if I could open the audio track in an audio editor, like Goldwave or Sound Forge...if so, I'd save it to wav format & use that for the audio.Stiiv -
It seems Vegas 8.0b has a problem with audio tracks on video compositings. Some audio tracks (it doesn't matter if AC-3, WAV or MP3) stop playing after a few seconds. Somethimes the application crashes. Same thing happens when you render the timeline. This is probably a BUG - Sony is already aware of it.
Check out the thread at:Originally Posted by cturtle
http://www.sonycreativesoftware.com/forums/ShowMessage.asp?MessageID=663757&Replies=14
Up grading to 6.0d will import the Audio. Getting it to play is another story.
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 14:06 -
sony vegas pro 8 rendering wont render video just audio and text
By bahlue18 in forum EditingReplies: 6Last Post: 12th Apr 2011, 07:31 -
How do you direct stream copy in sony vegas pro 8.0?
By ZZen in forum EditingReplies: 3Last Post: 6th Jun 2009, 09:51 -
.MTS files have no video stream in Vegas Pro 8
By meelisk in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2009, 09:40 -
Sony Vegas audio stream problem
By PoT in forum Newbie / General discussionsReplies: 11Last Post: 10th Aug 2007, 13:35
