tmpgenc itself will convert mpeg 1/2 to dv avi, but it is not straightforward.
1. de-multiplex the file
2. convert the audio separately: file -> output to file -> wav file
3. convert the video: file -> output to file -> avi file
4. check only the box for video
5. click on the thin line to the far right to choose your video codec
6. depending on the codec, but especially for dv avi, you will have to limit the conversion to about 9 min 30 sec (2 gig limit)
7. Go into setting -> advanced -> adjust the source range accordingly and repeat for the remaining segments of the video (overlap the out with the in points)
8. import all the new files into your nle (premiere )
9. edit the video then add the audio. done![/b]
Results 1 to 1 of 1
Convert TS/TS4 files to avi or mpeg
By Borg in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 20:11 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
HD MPEG convert to Huffyuv AVI
By christianolovesvideo in forum Video ConversionReplies: 19Last Post: 7th May 2009, 18:00 -
How can I convert WMV to AVI or MPEG?
By betlysmith in forum Video ConversionReplies: 6Last Post: 25th Nov 2007, 01:02 -
How do i convert VRO to Avi or MPEG ?
By CoffeehouseSchmuck in forum Newbie / General discussionsReplies: 7Last Post: 10th Sep 2007, 13:56
