Hi all,
I have an ATI Wonder 650 USB. When I attempt to capture in any of the Catalyst H.264 profiles, I either have no sound or no video. The Generic H.264 profile results in no video, but the audio is listed as AAC. The H.264 in AVI Container profile results in no sound and so does H.264 for PSP. The sound, by default, is supposed to be AAC (LC), auto selection for stereo etc, and a bitrate of 256 Kbps. I use the newest version of ffdshow, and Media Center Classic. I have, as far as I know from guides, made the proper selections for MPC to play AAC.
When I get no sound I get the following warning from MPC: MPC could not render some of the pins in the graph, you may not have the needed codecs or filters installed on the system. The following pin(s) failed to find a connectable filter:
C:\Users\Public\Videos\Recorded TV\Video Composite_20080114_1122.mp4::Audio 1
Media Type 0:
Audio: 0xa106 48000Hz stereo 256Kbps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {0000A106-0000-0010-8000-00AA00389B71}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 1326
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0xa106
nChannels: 2
nSamplesPerSec: 48000
nAvgBytesPerSec: 32000
nBlockAlign: 1
wBitsPerSample: 0
cbSize: 0 (extra bytes)
pbFormat:
0000: 06 a1 02 00 80 bb 00 00 00 7d 00 00 01 00 00 00 .¡..€»...}......
0010: 00 00 ..
Gspot provides the following concerning the audio: codec 0xa Stat: disabled in settings.
So, both MPC and Gspot "see" 0xa as the necesssary codec when the sound is supposed to be AAC. There is an 0xa codec for windows media player, but that does not work either. Also, Windows Media Player seems to "see" that the audio is AAC.
Any help is greatly appreciated.
Solution:
The problem is that regardless of which profile you choose, whether it be PSP H.264 (resulting in an .mp4 extension), Generic H.264 (resulting in an .mp4 extension), or H.264 in an AVI Container(results in an .avi extension), the file is saved in an .mov container. The files, however, did not play well in quicktime (which I would not want to use anyway). My solution was to do stream copies of the audio and video via MediaCoder to change the container (transcode) to .avi or .mp4. For some reason MediaCoder always tacked on a duplicate audio track which I removed using YAMB. The resulting files play perfectly.
AVI container encoded with H.264/AVC video and PCM sound
By LoLaha in forum Video ConversionReplies: 6Last Post: 20th Mar 2012, 23:14 -
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 03:15 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12 -
Anyone Have Experience Converting MPEG2 to H.264 with an ATI Avivo Card?
By drstew in forum Video ConversionReplies: 3Last Post: 24th Jun 2010, 11:00 -
H.264 Encoding - Sound Synching
By mabus in forum Newbie / General discussionsReplies: 5Last Post: 19th Nov 2009, 12:36
