I'm using VDub to extract WAV from AVI file but i'm having a li'l problem...
the extraced WAV does not have the same length as the video!
Video: 02:06:46
Audio: 02:06:44
how can it be?
how can i prevent it? maybe i'm doing something wrong?
any help much appreciated!
				Results 1 to 25 of 25
	GangstaRap wrote:
 If the streams do not go out-of-sync,the extraced WAV does not have the same length as the video!
 Video: 02:06:46
 Audio: 02:06:44
 how can it be?
 then there is no problem --- really.
	Midzuki,
 thats the thing:
 i'm extracting it in order to encode it to AC3 and then to mux it with MPV to create a DVD ...
 and it goes out of sync after compiling it with DLP...
 at first i thought the compiling was the cause to the out-of-sync DVD movie...
 then i've noticed the length differences as they presented above...
	What do you mean by "goes out of sync"? Does it start in sync and gradually get out, or is it out of sync from the beginning and stays out the same amount the whole way through. It's possible the audio has always been shorter and an offset was defined to keep it in sync. "Shut up Wesley!" -- Captain Jean-Luc Picard
 Buy My Books
	thanks for your help!
 i should try it...Originally Posted by ntscuser
 where can i get this plug-in?
 is it free?
 after compiling to DVD it starts in sync and then gradually get out...Originally Posted by gadgetguy
 actually when i'm thinking about it - the fact that the audio go out-of-sync gradually does indicated that the audio stream shorter than the video... doesn't it?
 or maybe i'm just coming-up with a stupid assumption?
 the original AVI file is fine, the audio sync - thats what i don't understand...:Originally Posted by gadgetguy
 how can the audio be in-sync when its an AVI - but then to get shorter when its been extracted and to cause later to an out-of-sync DVD video...
 it's so weird...
	http://tmpgenc.pegasys-inc.com/en/download/tsp_ac3.htmlOriginally Posted by GangstaRap
 Not free (requires online product registration) but is 100% DVD compatible. You don't say what you're using to convert to AC-3 at present? Not all AC-3 encoders are DVD compatible.
	the audio listed in the avi is already ac-3. don't convert to wav and back to ac-3. use the original and don't convert it at all.
 but... it's just a guess are you making a ntsc dvd out of it?--
	i'm using EncWAVtoAC3 to do itOriginally Posted by ntscuser
 how can i extract the AC3 audio from the AVI without decompress it to WAV?Originally Posted by aedipuss
 nope...Originally Posted by aedipuss
 it's a PAL video...
 why?
	You can use AVIMuxGUI, but this usually packages the audio in .mka which you would then use mkvextractgui to separate the ac3 by itselfOriginally Posted by GangstaRap
 or
 You can use AviDemux in 1 step by selecting audio (at the top) => save (make sure you enter location, filename and extension e.g. "myaudio.ac3"). The sidebar audio drop down menu should be set to "copy" since you want to keep it AC3.
	It's easier to right-click on the selected track and choose the option "extract binary".You can use AVIMuxGUI, but this usually packages the audio in .mka which you would then use mkvextractgui to separate the ac3 by itself
	the pal/ntsc question was because most in sync to out of sync avi conversions are a result of changing fps from 25 to 29.97. but if you are pal -> pal then that doesn't apply. --
	thanks for your great help!
 when trying to use AVIDemux to do it - the demuxing process aborted after 50% of progress... (?)
 and when trying with AVIMuxGUI,:
 again...Originally Posted by Midzuki
 this is after extracting with AVIMuxGUI,:
 different length...
 i might need to mention that originally the AVI file was two separated AVI files with out-of-sync audio and i used VDub to sync them one by one with the same method (using "Interleaving" > "Audio skew correction") then i merged them together to one AVI file...
 i guess thats what causes the problem huh?
 i really hope you guys have more ideas because i'm starting to think it's a lost case....
 Thanks again...
	The easiest way I know to demux ac3 from an avi is to use virtualdubmod.
 Also don't merge the avifiles. Process them seperatly (demux audio and encode video of file1 then do the same for file2). Then when finished import them both into dlp and let it merge them.Donadagohvi (Cherokee for "Until we meet again")
	If freebird's idea doesn't work, or you don't have the 2 original AVI files,
 It depends if your audio is -2000ms for the beginning (constant) or if there are 1 or more errors somewhere later (more complex to fix)
 If it is always -2000ms out of sync (from the beginning and stays constant), you can just fix it with AVIMuxGUI (right click the audio track)
 If it gradually gets out of sync, you could also try and expand the audio by +2000ms by using adobe audition or some other audio encoder to see if it matches
 If there is more than 1 "error point", you have to cut each segment and process each individually (=not fun)
	freebird73717,
 how can DLP merge two video & audio streams?
 poisondeathray,
 i've just noticed something:
 the audio stream is in-sync from the start but its getting out of sync at once - exactly at the point that the two original AVI was merged - i mean - exactly at the joinder point (where one AVI is end and the second starts)...
 starting from the joinder point - the audio constantly preceding the video by approximately 1 second...
	Just add file 1 and file 2 as seperate movies on the same titleset. When dlp authors it will mux them together and play them seamlessly. Donadagohvi (Cherokee for "Until we meet again")
	You might have mentioned at the start that you had joined two files. Then you would have been told, days ago, that this is a common problem and not join the files the way you had. The more information you give up front, the better the information you will get in return. Read my blog here.
	@Gangstarap
 I've seen this a couple of times. Both files would be in sync on their own, but when I joined them the sync was off in the second half of the joined AVI. What I ended up doing was finding the delay in the second half of the joined file (using MPC). Then I applied this delay (with Vdubmod) to the original second file (even though that made it out-of-sync). I then joined the original #1 file with the #2 (delayed) file, and after that the new joined file was in sync throughout. Clumsy workaround, I'm sure there are better ways, but it worked for me.
 But I didn't convert to WAV or to DVD, I just wanted to make a 1-piece AVI. Might be worth a shot, though.
	guns1inger,
 you absolutely right...
 sorry for that...
 i just didn't think this fact matters to much...
 now i know...
 before i'll try this hard work i want to make sure i tried any other simple way...Originally Posted by Squash
 and now i also think i know what the problem is...
 this is the original File1:
 it match...
 and this is the original File2:
 the thing is that in File2 i don't have any sync problems (as long as i'm not demuxing the file) though the "File Information" indicate that the audio shorter then the video...
 how can it be?
	Simple. That 2nd part has a nearly 2 second negative delay. You join the 2 parts and the second part goes out of synch by the same amount. Do what squash said, if you have to join them. I agree with guns1inger; a little common sense on your part would have solved this several days ago.how can it be?
  AC3 Dialogue Normalization so it doesn't change volume of edited originalBy c627627 in forum AudioReplies: 13Last Post: 8th Jun 2011, 23:20
  Recorded DVD picture jumps, original VHS source doesn'tBy bigj7489 in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 09:09
  Converting from VOB to any other format - doesn't keep the original sizeBy Mylo in forum DVD RippingReplies: 5Last Post: 14th Mar 2009, 14:58
  video doesn't fit my TV screenBy hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 07:56
  subtitle that doesn't fitBy Belfour in forum SubtitleReplies: 5Last Post: 14th Aug 2007, 09:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
