Hiya all,
I need some help. I have a file here I am trying to convert to dvd format and so far everything I have used has sent the audio out of whack.
If I watch the file on my PC it is spot on but I have tried the following methods and the audio is stuffed on each one. I am not talking about a couple of frames out either. In on instance it was about 5min out.
1/ I used Nero Vision to import the AVI, set it and burnt it. Audio out!!!
2/ I used TMPGenc 4.0 Express to convert and audio was fine on the outputted file. I then used Nero to convert and burn and audio out of whack.
3/ I used TMPGenc 4.0 Express to convert and audio was fine on the outputted file. I then used TMPGenc DVD Author 1.6 to convert and audio out of whack
4/ I used VirtualDub to change from VBR 3.0 audio as per the sticky post and this sent my audio out of whack aswell.
Here is the file details:
I am hoping someone can assist in ideas to keep trying.FILE_NAME Ice Age 2.avi
FILE_NAME_WITH_PATH \\LAPTOP\Users\Wacko\Documents\AAA - Movies\Ice Age 2\Ice Age 2.avi
FILE_SIZE 760,862,720
CONT_AUDIO_STREAM_COUNT 1
CONT_BASETYPE AVI(.AVI)
CONT_BYTES_MISSING 0
CONT_INTERLEAVE_ALIGN Split
CONT_INTERLEAVE_PRELOAD 24
CONT_INTERLEAVE_TIME 42
CONT_SUBTYPE OpenDML (AVI v2.0),
CONT_TOTAL_BITRATE 0
VIDEO_ASPECT_CONVERT_AVI1
VIDEO_ASPECT_CONVERT_AVI2
VIDEO_ASPECT_CONVERT_CVD1
VIDEO_ASPECT_CONVERT_CVD2
VIDEO_ASPECT_CONVERT_DVD1
VIDEO_ASPECT_CONVERT_DVD2
VIDEO_ASPECT_CONVERT_SVCD1
VIDEO_ASPECT_CONVERT_SVCD2
VIDEO_ASPECT_CONVERT_VCD1
VIDEO_ASPECT_CONVERT_VCD2
VIDEO_ASPECT_SOURCE_MATCH
VIDEO_ASPECT_TYPE_NTSC
VIDEO_ASPECT_TYPE_PAL
VIDEO_BITRATE 932
VIDEO_CODEC_NAME XviD 1.2 SMP
VIDEO_CODEC_STATUS Codec(s) are Installed
VIDEO_CODEC_TYPE XVID
VIDEO_DAR 1.857
VIDEO_DURATION 1:31:04
VIDEO_FIELDS_PER_SEC
VIDEO_FRAME_COUNT 131002
VIDEO_FRAMES_PER_SEC 23.976
VIDEO_H264
VIDEO_MPEG2
VIDEO_MPEG2_3X2
VIDEO_MPEG2_BFF
VIDEO_MPEG2_I_L
VIDEO_MPEG2_PPF
VIDEO_MPEG2_PROG
VIDEO_MPEG2_TFF
VIDEO_MPEG4 MPEG-4
VIDEO_MPEG4_BVOP B-VOP
VIDEO_MPEG4_GMC
VIDEO_MPEG4_NVOP
VIDEO_MPEG4_QPEL
VIDEO_PAR 1.000
VIDEO_PICS_PER_SEC 23.976
VIDEO_QF 0.185
VIDEO_SAR 1.857
VIDEO_SIZE_X 624
VIDEO_SIZE_Y 336
AUDIO_BITRATE 177
AUDIO_BITRATE_TYPE VBR
AUDIO_CHANNEL_COUNT 2
AUDIO_CODEC 0x0055 MPEG-1 Layer 3
AUDIO_CODEC_STATUS Codec(s) are Installed
AUDIO_MPEG_STREAM_ID
AUDIO_MPEG_SUBSTREAM_ID
AUDIO_SAMPLE_RATE 48000
Thanks in advance.
Many responses (to numerous to count) to your kind of problem suggest using FAVC (free) or ConvertxtoDVD (Trialware). You may want to give those a shot.
Hiya,
Thanks for the feedback so far.
I used FAVC under HC encoding and it still spat out my DVD with about a 5 min displacement in audio. Am trying it again using the QuEnc section to see what it does.
It also took near on 3 hrs to convert. Is this normal for FAVC? My laptop that I do my conversions on has pretty high specs and I can normally encode using TMPGenc in about an hour and 10min to burn the disc. -
If those are the specs in your profile then a) they aren't that high any more, and b) the timing sounds about right. On my Quad core a full movie takes less than 30 minutes using HCEnc on Best settings.
HCEnc is a far better encoder than ConvertXtoDVD or Tmpgenc Xpress. The cost of quality is speed.
You might also have to face the sad fact that your file may be screwed, and short of manually adjusting sync after encoding (simple if the difference is a constant amount) you might not get a conversion. It happens.Read my blog here.
Hiya,
Sorry, just adjusted my specs, but these are for my PC, my laptop specs are higher CPU but lower RAM.
I used the QuEnc and this is about the same with the gap in audio. Just trying it in avi2dvd to see if this works, otherwise I came to the same conclusion that the file may be screwed.
Why would the conversion to mpeg (dvd format) through TMPGenc work, yet when I convert it to VOB files etc for DVD it get screwed? I haven't had this on any other files and I have done quite a few in my time. -
Well, I have given up on this!!!!!!!!!!!!!
I tried using avi2iso and convertxtodvd and both still gave the audio problem.
This file is now in the bin and I will move on.
Thanks to the guys who tried to help. I now have some additional software to use if I stumble over this problem again.
Cheers 8)
Problem converting dvd to avi or mpeg
By JARRE2000 in forum Newbie / General discussionsReplies: 5Last Post: 30th Nov 2010, 16:43 -
converting .rm to mpeg, avi using eo video problem!!
By convertme in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2008, 01:37 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 18:50 -
By Kareng in forum AudioReplies: 1Last Post: 2nd Jul 2008, 16:56 -
Problem when converting DV AVI files to MPEG
By MI6 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 15:34
