Hi, y'all. I have some TVB series which are in .AVI, around ~300MB each file, and each one of them has 2 stream audios. One is Cantonese and the other is Mandarin. I want to burn them out onto DVDs so i could watch on a standard DVD player. Could anyone show me how to convert these .AVI to DVD with only the Cantonese audio? Thanks
Depending on the AVI format, you could drop them into VirtualDub or VD Mod and delete the audio you don't want, then save both the audio and video out as a direct stream copy. This is fairly quick and no changes are made to the video or the audio file you selected.
If you use a different save filename, it also won't damage the original file. Then you can check to make sure it works, then delete the original version. -
Thanks. I'll give it a try when i get to home. Thanks again and have a nice day.
hi. I have downloaded VirtualDub but i don't know how to separate the audio and video i want. Please help...
Just use VirtualDub Mod ( NOT VDUB )
- menu video : direct Stream copy
- menu streams :
there is 2 in there
click one of them to select and hit DISABLE button
- menu file : save as...avi
as because you don't know what of them are in Cantonese, you maybe need to do this twice -
It's a lot easier to do in VirtualDub Mod. Just select 'Streams>Stream list' and you should see both audio files. L Click on the one you don't want and Delete or Disable it at the bottom of the right menu, then save the audio and video out in 'Direct stream copy'. (The default setting for audio, but you will have to choose it for video.)
Use a different filename to 'Save as' if you don't want to overwrite the original, at least until you've tested it.
This isn't working for me. I followed your guides and did successfully disable the un-wanted audio, but the output is way outrageous. The input was about 300 MB, but the output is 1GB! please help. There's also no "Save" button, just "Save As.."
ffmpeg can transcode both audios on "dual avi"?
By CactusMan in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2012, 07:25 -
TMPGenc CAN NOT CONVERT AVI LF RT CHANNELS TO 2 AUDIOS
By suijaypao in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 05:03 -
Karaoke DVD -> Chapters (2 audios) -> .mpeg (2 audios) ???
By webking1 in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2009, 11:49 -
Troubles burning avi to a dvd with nero vision
By falcon1 in forum Authoring (DVD)Replies: 3Last Post: 13th Oct 2008, 11:36 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
