I downloaded the Lame Codec pack but it's not showing up in VirtualDub. I go to compression but all I see is MPEG Layer-3 which is not the Lamemp3 codec. It doesn't allow me to change the sampling rate or anything like that. Could someone explain to me what I have to do?
FYI - I'm running Windows Vista.
There are several versions of the Lame package. With VirtualDub, I use the ACM version: http://www.rarewares.org/mp3-lame-dshow-acm.php#lame-current-acm Works fine with Vista and VD Mod.
I haven't tried using the directshow version, but others may be able to help with that. -
I have the same problem expect its on XP. This is really bothering me.. it just magically goes away. Infact just yesterday it shows up in Virtual Dub and today its gone. Its done this b4 too. Its random. Its pissing me off.. does anyone know the problem?!??! I have projects that I'd like to finish and this lamemp3 is the only one thats worked out for me the best. If anyone else has better suggestions- please tell me.
Codecs gone, not showing up in VirtualDub or other software....
By ggouweloos in forum Video ConversionReplies: 19Last Post: 15th Sep 2012, 00:24 -
Avi showing wrong length. Encoded with virtualdub
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 3rd Nov 2011, 13:06 -
Subtitles not showing up in VirtualDub
By vaskimies in forum Video ConversionReplies: 2Last Post: 18th Jun 2011, 14:29 -
No audio devices showing up in Virtualdub. ASIO plugin needed??
By greggery in forum Newbie / General discussionsReplies: 3Last Post: 16th Apr 2011, 20:37 -
Subtitle not showing w/Xvid in Virtualdub
By luketheduke in forum Video ConversionReplies: 10Last Post: 4th May 2007, 15:58
