I've been looking for a couple of years for a program that will play DVD's at 24 frame per second for some time now. Does one exist? What I want to do is take a film DVD, insert it into the play and have the software play it back at 24FPS and the audio at 46080hz, and play as originally intended.
Whenever I ask on forums I seem to get a barrage of abuse from people saying I am mad for wanting to do this. I don't know why, there may be some conspiracy to get us in PAL countries to watch out films too quickly. But I have faith in the good people of the VideoHelp forum
If the software does not exist, is there a good place I can request for suc ha piece of software to be developed, like sourceforge etc.?
Cheers folks!
Rob,
Ha ha, well thanks for the suggestion, but what i am looking for is playback of the Pal version at 24 fps. It should be really easy. Scaling the audio is the only potentially tricky bit. I can get it doing about 23 FPS just by changing my sound card's playback rate from 48,000hz to 44,100hz. But my sound card scales all the rates in hardware anyway.
It doesn't actually need to do much. Playing back at 24 FPS should be less work than playing back at 25. It might even be possible to hack it into existing software, or revise an open source project.
Any ideas?
Cheers,
Rob, -
Cheers for that! I'm not too sure about how it scales the audio but the video looks pretty cool!
Originally Posted by McGonicle
You may be somehow getting the sound to appear closer to 24 fps by this change, but that has nothing to do with the frame rate at which the audio is being played.
I've read mixed reviews of TruSpeed. Maybe it will work for you. -
Actually, the sound rate does have something to do with the sound rate as the video in most application will maintain sync by using the the audio crystal as a reference. Most video applications I use change the frame rate when I change the sample rate on the audio card.
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 13:21 -
Vista64 playing wow with low fps
By johns0 in forum ComputerReplies: 13Last Post: 28th May 2007, 19:57
